i am well aware of what is needed to do a a20/turbo build.
but i'm going to do this with what i have access to. i have done abit of searching around the net but i still have some q's.
1. i dont want to spend the $$$ for boost retard, so can i just retard the cam gear 1 tooth to prevent detonation?
2. can i use a basic dual stage adjustable fr instead of a fmu(unless they are resonable then i will get one)?
3. will a fuel pump from a corvette w/efi 427 v8 provide enough flow(brand new for 50 bucks!)?
4. the port that the map sensor plugs into on top of the intake manifold, is it the same as vacuum or is it diferent?
5. ^^^ what would happen if i move the map sensor to before the turbo to prevent a diferent reading to the ecu and thrown into limp mode?
i plan on using the stock manifold with an adapter that i will make. so i will probably make it with a bend and try to make use of that space inbetween the rad and the engine. i will be using an intercooler, so far i have a choice between volvo and dodge cars for turbo w/intercooler. i'm going to spend sometime at the yard looking for a turbo with the least amount of shaft play and internal wastegate. i will probably end up making my own bov (throttle & clutch controlled).
this project is meant to be simple and cheap, i have 2 a20's, one of which i'm rebuilding for boost. and the one in the car now i'm going to boost for the hell of it(314000k) tested 160psi accross, leak down test within 10psi @ 90psi.
my injectors were reflowed and serviced, injector guy tells me that they are now good for almost 270cc @ 45 psi (i think thats what he siad).
flame away.
