had anyone of here know about this weber??i try to search on the net....couldnt find any link or info about it.......if anyone familiar..can give wat series is it??
and yeap..its weber!.....wat series??
Weber is nice and price but they are most for muskle cars...
My Build Thread
judging by the two different sizes on the throttle plates, my guess it is a 32/36 two stage type. maybe earlier style they made for bugs is what I think.. linkage looks like vw bug too. A keeper for sure, it a racer type cuz of the air horn design its "trumpeted"
At least it looks like two different size throttle plates in that picture anyway.. where did you get it?
Hmm, I'm not so sure it's for the VW's. They were IDF's I believe and bolted on with one barrel per cylinder, just like the DCOE's go on the Hondas. I suppose you didn't HAVE to do it that way, but otherwise you've got a great big manifold down there to join the flow from both barrels, then split it back off to two barrels... Oh of course I guess unless you mean a single carb VW setup... I suppose that would work..
they made a kit for single set up in the middle for stock carb replacement, yeah that definatley is not DCOE TRUE , back in the eightys they had that one an another one barrel bad ass holley, called bug spray, I have not seen one of those in a long long time.Originally Posted by 2ndGenGuy
I was looking at the throttle linkage,it takes a cable with a curl similar but not as big as accord. I am confused some about some of the extra hoses and one of the clamps looks like a crimp style oem for something. maybe it went on a jeep.
A20A1 MAY KNOW if he makes it around to this thread, Im sure he will .I have been too busy to spend more than a few minutes online, and It looks like I missing a bunch, and people are selling all thier cars, is it the end?,,, lol
okay..thank you guys.....i get this weber at junkyard....after cleaning it last nite.....i found some info on it.....stamped/engraved at the bottom base were 32/36 CFR 3/100 3N.....so what i do think it is CFR series.When on internet look for it....goshhh!couldnt find anything on it......
if some know about it...do share some info..i need to know how it works......maybe i link of info of it.
Thanks.
gorgeous
there he is, i knew he would appreciate that piece. those are wicked looking yet ancient mechanical secondaries. has to be bug , jeep, ,if it didnt have adapter plate rigs, it was oem on some kinda upfitted small truck or euro something. its cool as sh*t find.Originally Posted by A20A1
Were are the booster venturies though?
I wonder if it could be EFI or TBI
nah it proably as some annular venturi then?
DAT where did you get it , did you take it off something or it was on a shelf or pile .
and
as for post by A20A1... annular? your back 56K huh lol lol lol, yea I was curious about the pics too, one is short , almost looks like two diff. pieces. Was there a sidedraft two stage?
all I know its an old carb and two stage, someone with a weber book should be able to tell ya DAT, I have not one....yet
Look how thick the base plate is.
Where are the booseter venturies? Am I not seeing all of the pictures posted?
I'm almost wanting to say someone hooked up a TPS and injectors
Get some more pics if you can.
those webers look sexy, 2ndgenguy was telling me how easy/good they are compared to the kehin or w/e its called
What about a diesle?
i really dont understand that comment![]()
did you say diesel A20A1, no way they would use injector pump and bunch of steel lines, but funny thing I was re-reading the thread and the thought came across my mind of propane like a forklift or work engine of some sort, then you said diesel. I dont know what OD was talking about btw.Originally Posted by A20A1
DAT, come back here dude with your findings Im wondering where is the rest of it. I still wanna say bug carb retrofit for oem but something about the way the air breather flange is mysterous.
yeap...no boost venturi makes me wondering how it works......Originally Posted by roodoo2
but then i managed to get some info on it.....its coming from Renault 1.6 and the CFR stand for Compeign..bla..bla...Renault sumthing like that...and weber supplies to renault as OEM parts....but not sure on which renault.....
roodoo2...this is my 1st time i found the rare weber at junkyard......and when i found it its not attach on any engine..just lying at the corner of shelf.....
i will try to snap more pictures on it since i already cleaning it...and i think(just think) i know how its work.....but then i still look any info on it.
try to figure this....comparing the base plate design...
this is my last DGAV at bottom plate....
this one is weber that been talking bout...see the diffrent(been circled in red)
and this jetting lead to the hole on the center of bottom plate....
but what i couldnt figure out is...How the hell fuel been supply??
Could someone list the advantages and disadvantages to converting our 3geez to Weber?
pros: more power, less problems.
cons: won't pass emission test.
Mine 3gee is slow, so more power would be quite nice.
How much more HP?
Originally Posted by shepherd79
There is a HOW TO and plenty of info on the weber conversion if you want to spend time learning it...like I did.Originally Posted by bushbean
Much more power to me, but yet I did a valve job, head shave, header at the same time. I feel my car would easily hit 100mph in a short time, I am still working bugs out of it yet. MY short test drive really impressed me, but I got my weber off a mazda truck , it may or may not coincedently have the proper idle jet in it. I just have not had time, it has the power but I am leary of running it out too hard yet, and the transmission cable is needing some fine tuning, as well as timing.
dat/// its all good, I was just wondering where the carb came from, it looked so wierd. If it came off renault, I still may be on to something with it being a workhorse engine carb, and possibly propane as well. Definately a cool conversation piece so far ehhhh...
one thing is for sure is it makes the cars a lot easier to work with once it is converted, and the engine compartment is a lot simpler. I have had problems with getting the exhaust situated like I want it , I dont want to drive it much sounding like it does nowllOriginally Posted by bushbean
I'm not sure if he posted this yet, but shepherd found an informative article on the distributor timing curve adjustments, one of our distributors was used as an example.
Anywho that right there is something I would have loved to have around when I had my car, that way I could get rid of my lag on the bottom end and help max out my top end.
here are the picture of jetting i took out last nite...
