I just finished replacing the timing belt, along with the power steering, AC, and alternator belts and the water pump and crank and cam seals for good measure on my '88 LXi auto. Ran into a funny problem with it and you guys seem to know what you're talking about. If you're as hopefull as I hope you will be maybe I'll stick around![]()
Anyway, after changing all of the above I let the car idle in the driveway for ~10 minutes while I cleaned up. Turned the AC on and off, reved it a few times, backed it down the driveway ~20 feet to make room. All seemed well. Shut the car off and go in for dinner.
I come back out ~3 hours later for the rolling test, and the problem(s) start. The throttle response is nearly non-existent. Pulling off the line feels like I just took my foot of the gas and let it coast. No matter how far I push down the petal, it just creeps forward. Once the RPMs finally reach 2-2.5K the throttle kicks in. It I happen to have the petal to the floor at that time, it jumps like it should. If I happen to be off the gas at that time, it continues to creep as it should. It's only an issue at the very low RPMs in first gear. Once I get up to speed, its like nothings wrong.
If I didn't just change the timing belt I'd be looking into a throttle/vaccum/cruise control issue. Since it worked fine before I decided to be responsible and do my preventative maintence, I must have tweaked something. I found the threads below, so I'll be double checking everything tomorrow or the next day. Any other ideas?![]()
https://www.3geez.com/forum/showthread.php?t=43295
https://www.3geez.com/forum/showthread.php?t=55443
https://www.3geez.com/forum/showthread.php?t=53911
