Results 1 to 12 of 12
Thread: intake question
    intake question
    HI.
    I was reading threads on custom intakes and couldnt get from all the posts what is wrong with the original one.The one in my car (probly stock) goes into a hole near the battery and probly comes to the grill at the bottom, since I dont see it going anywhere else (Looks like it'd be sucking on pretty much cold air) . So my question is what is so wrong with it that people redirect the pipes into the engine compartment or outside of the bumper?My car is 88 Ex-i if that makes any difference (I saw both carb and EFI with intake mods but alot more carb ones ,dont know if it makes difference )
    thanx.
    LX User 3rdGenMartyr's Avatar
    Jun 2002
    89 lxi sedan with 300k on the motor
    Bonne Terre, Missouri
    i dont think that its so much running it to the outide of the car but the shitty concept behind the airbox.....
    the flow comes from the well, then into the top hole on the box where the filter is, then it travels to the bottom of the box and leaves through a port under the inlet and does a complete 180 turn into the intake, if the box was right on the intake it wouldnt be that big of a deal, but that 180 degree turn kills almost all airflow into the intake, thats why i opted for a custom made PVC intake (im broke) over a cromed out intake, just to stop all the air restriction coming from the useless piece of crap that is the air box
    can i loan you some mileage, i got enough to go around
    Can someone then tell me why u would change the pipe itself ,while u could stick the new filter on the existing pipe and avoid the airbox?Maybe change the pipe to something that doesnt get as hot but why not have it going into the bumper where the original does?
    thanx
    2.0Si User 88LXiHB's Avatar
    A moneypit!
    Vegas, baby!
    For it to go into the bumper it would have to be a cold air intake, and since no one makes the for 3rd Gens, most people just buy a 92-95 Civic Short Ram (under hood) and cut 4 inches off the filter end.....I did the latter, and notice a pretty significant performance increase over stock..I'm not saying "I gOt 15 HorsEpOWer, DawG!!", but you could deffinately tell the short ram made a difference.
    The GSX was killed, I need something new...
    Yeah but the pipe disappears into the hole which leads to the bumper( or close to it in the left bottom corner of the car ) so its gotta be sucking cold air as it is ? right?
    I am new here and might be missing something obvious so if u could clear that up for me id be greatful
    Feb 2001
    '87 Accord LX
    Renton, Washington
    The whole point of a cold air intake (or any aftermarket intake) over the stock intake system is that as said earlier, the stock system is very restrictive. A larger diameter pipe with less turns and no airbox will help this. The more air the engine can get, the more power (cold air is the best).
    LX User Experimental_Honda's Avatar
    Jul 2002
    94 accord lx, 88 sold
    ky
    i custom fitted a dc sports dac short ram intake for a 92 civic in my car, it does not make to much diffrence unless im really getting on my car.
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    I can definitely tell a difference with my short ram air intake. Since i put it on, it seems like my tires chirp everytime i take off (and when it switches to 2nd gear at high rpms). Also, it made my car hella loud and it definitely looks cool, and frees up space in the engine compartment :p
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    1988starter
    Guest
    I love my AEM intake
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    I gotta get me one of those....No fucking time though..
    R.I.P. Died on 7/2/03......
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    he problem with the stock one is that it's very restrictive
    the twist and turns
    and the resonator box to keep the noise level down.
    It's actually not cold air (well, sort of). If you look at the right side near the head lamp motor, you'll see the intake pipe coming back up from the fender from the resonator box
    LX User Toby's Avatar
    Read Signature
    Australia, Rockhampton
    This is what I am planing to do once I have an after market intake system. Get the black box where the stock system gets its air from and drill holes in it (the side of the box which faces the front of the car) not too many and also drill a few holes in the bottom of the box this is so any water that gets in the box can run out. And then have the air filter there were the pipe comes up from the box into the engine bay so the filter picks up all the cold air comming up from were I drilled the holes.
    The only thing I would have to do is make the intake pipe my self what would be best for that??
    -Eike
    __________________
    Honda Is The Best
    I Bought My Accord On 25th March 2002
    I Wrote My Accord Off On 26th April 2003
    Soon I Will Be Driving Another Honda
  1. Air Intake Question
    By nomercy0632 in forum Performance
    Last Post: 09-01-2009, 08:03 PM
  2. Intake question?
    By JFreddy in forum Performance
    Last Post: 10-12-2004, 09:02 AM
  3. intake question
    By hondaaccord_86 in forum Carburetor Tech
    Last Post: 08-10-2004, 10:58 PM
  4. question which intake will fit...
    By Micah 89LXi in forum Performance
    Last Post: 10-29-2003, 10:44 PM
  5. New intake...Now the big question...
    By 89bumblethumper in forum Performance
    Last Post: 08-07-2002, 02:00 AM
