I've searched but I can't say I've come up with anything definitive, perhaps there isn't a definitive answer, but bare with me.
My '89 has been blowing the blues on cold starts now for the last 2-3 winters.
The first couple winters it had to be close to or under freezing for it to do it, and then it would only be for under 30s. Now it will do it if its been below 5-8c overnight and for up to a minute.
Over the summer there is no visible smoke at all from the car. Once the car is warmed up in any weather, I can floor it up to 5000rpm and there is no smoke.
It had good and even compression the last time it was checked.
My deduction is that it has to be the valve seals and that they have just deteriorated further over time, but I've seen it suggested that the guides are likely the culprit when this happens. The engine runs about as good as it ever did otherwise. 21inches at idle.
I'm thinking of having the seals replaced. I don't really want to spend the money, but I'd rather not drown my neighbours in blue every day I decide to use the car in the winter.
I'm just kinda down over this as it is the first car I ever owned and I'd like to keep it somewhat respectable without blowing too much money on it.
I was even thinking of dropping the fast idle speed to keep it from billowing out as much as it does now.![]()
