Hello, I have a 1986 Accord LX w/A20A1 engine with 190,000 miles. My dad and I recently replaced the head on it, and after reassembling the intake to the head and the carb to the intake, we have had trouble with fuel delivery it seems.
Before reinstalling the carb, I disassembled it and cleaned it out with carb cleaner, making sure no rubber parts or diaphragms were contaminated. I then bought that $30 rebuild kit from O'Reillys Auto Parts and put new gaskets, o-rings, and a diaphragm (I think for the accelerator pump) in. I also installed a new intake to EFE plate gasket, so I think that's alright. We have hooked up all of the vacuum lines we know of which were disconnected, and double-checked to make sure they matched-up alright. As far as we know, they are in the right places.
We were able to start the car and keep it running, but it idled poorly. It acts as if it is always running too lean, since I can make it run very smoothly (and speed it up) if I place my hand partially over the primary bore of the carb or close the choke a bit.
I made sure the float level is centered in the glass window, and I have even tried to adjust the A/F mixture, which had little, if any effect on the way it runs. I can adjust it to the leanest it will go to, all the way in, and it will still run. I believe this is abnormal?
The gas is fresh, and as far as we know the vacuum hoses are hooked up correctly... although it may be easiest to take some pictures and show you where each of them are going.
One last thing which we still need to do is time the car, but I know there is definitely a problem with the amount of fuel getting to the engine since I can make it run better with a restriction of airflow. I have the idle around 1100, but when I partially cover the primary bore it goes up about 600 or 700 rpms. I also have checked the venturies to see if they were loose... I replaced the o-ring for the primary venturi.
I've looked around on this forum quite a bit so far and foumd it very helpful, but I am still at a loss for what this could be. Sounds like vacuum or internal carb problems to me, but it's hard to say. We've yet to perform a vacuum test on it. The engine backfires out the exhaust until the primary bore is partially covered, then it smooths out and misses cannot be heard.
Any ideas? Thank you very much for any help you may have.
