Results 26 to 50 of 77
Thread: ST sway bar is rubbing
    Jun 2001
    Boston MA
    Re: ST sway bar is rubbing
    any update on this before i order me some bard
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    I just ordered ST bars from summit, they're on backorder and it's going to be more than 2 months before they can get me a set.
    That's a long wait!
    Link to my 3geez garage
    Quote Originally Posted by thegreatdane
    That's a long wait!
    Holycrap 2 months! That seems like a sign that they will not be making them much longer. I did manage to get one side to quit rubbing, by loosening the bolts and using a pry bar to pull the bar down a little. I will do the other side when I install the new suspension.
    Jan 2003
    Denmark/Europe
    Yes, I fear so too. Someone should buy the last ones and make a killing of selling them on ebay lol
    i should look into getting some soon
    carotman's Avatar
    Montreal South Shore
    I'm glad I got mine then.
    I should get the front one sooner than expected I guess.
    I need these parts!
    LX User Estimated Prophet's Avatar
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    *cough* vigor rear sway *cough*
    Honda Parts Connection -- http://www.acurahondaparts.com
    D Series Army Dishonorable Discharge
    BT Defector
  8. #33
    SEi User
    south dakota
    legend, just drop the motherfucker down..extend the link a little.
    yeah I'm crunk right now, I don't care. Yeayuh!
    Why did you chose the ST over the addco? What should I get? Did you look into the vigor bar?
    Another thing, I know I shold probably PM you about this instead, but what kind of gas mileage do you get? I'm really pissed that my b series gets worse than my a20. A lot worse. I can watch my gas gauge move, wtf. there's nothing wrong with my motor, I built that piece of shit myself.
    Anoher thing, I improved my wheelhop problem a lot too, did I tell about about that? Softer mounts + repositioning=good..
    Sorry to be off topic and shit, I'll post up on h-t about the mpg thing, I was just wondering.
    I also wonder what 1600cc injectors and a t4 twin scroll gt35r will do..lol
  9. #34
    Quote Originally Posted by Accordtheory
    LOL, you must be blitzed. I will fix it when I install my full bodied coilovers. I went with the ST cause they are larger then stock, they come with poly bushings, and they are reasonably priced, also addco was/is not available. I haven't checked into the vigor bar. As for the gas milage, I have a very low thermostat and the car runs rich. In the winter I get 22-24, and in the summer I get 25-26. Sounds like you need a tune . I'm glad you got the wheel hop shit figured out, that gets incredibly annoying after a few launches.
    REALLY REALLY shitty gas mileage, but fast car .
    Drink one for me
  10. #35
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    you were right tho antares, mine is no where near that close to the c-arm. are the se-i brackets different?? im going to the yard tomorrow ill do some comparing.
    '89 SE-i Coupe
    Awaiting Garage
  11. #36
    I would check out the 86 LX-i sway bar bracket, it is a more similar setup then the se-i bracket.
  12. #37
    http://www.preludepower.com/forums/s...d.php?t=260017
    maybe this would help? might be self defeating not sure really.
  13. #38
    Jan 2003
    Denmark/Europe
    Quote Originally Posted by Oldblueaccord
    Performance endlinks? lol.. I dont see the point of those as far as performance goes, only if your swaybar is hitting something, and in that case I'd rather mock something up myself.
  14. #39
    Oct 2000
    '88 Accord LX-i
    Connecticut
    There is another option for rear sway bars that I will be posting in the coming days...
    '88 LX-i Coupe --- LS/Vtec
  15. #40
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Vigor rear bar!
    Alex
  16. #41
    Jan 2003
    Denmark/Europe
    A big fat I-beam perhaps :p
  17. #42
    Lets just weld a bar from the bottom strut mount to the other bottom strut mount .
  18. #43
    2drSE-i's Avatar
    Oklahoma City
    solid rear suspension lmao
    '89 SE-i Coupe
    Awaiting Garage
  19. #44
    Jan 2003
    Denmark/Europe
    Let's sell it on ebay as a DIY kit lol
  20. #45
    SEi User
    south dakota
    So it never goes into closed loop?
    I would always run the stock thermostat, or close to it, for the reason that the engine is built (clearance wise) with that temperature in mind. A cooler block will decrease your piston/cylinder wall clearance, for example.
    I guess I'll get the st bars, I don't know. I'll still look into it more, like maybe an st front and vigor rear bar (?) but I know the rubbing problem would be an easy fix regardless..
  21. #46
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    I put the Vigor bar on my hatch with little effort. You have to shave the bushings a bit to get that huge sucker to bolt up but other than that no problems.
    BT Defector
  22. #47
    SEi User ZackieDarko's Avatar
    but will the vigor bar work with rear discs?
  23. #48
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    I have drums
    BT Defector
  24. #49
    Quote Originally Posted by ZackieDarko
    Im sure it will, the bars all bolt on the same between drums and disks.
  25. #50
    it gets warm enough to go into open loop, but just barely. I will get a stock one when this one needs to be replaced. I am on 10K with this motor and it's still running strong, so I think everything is good for now.
  1. rubbing
    By dub88acc in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-06-2004, 12:45 AM
  2. 16's rubbing!
    By 86ACRDLX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-21-2004, 11:00 PM
  3. my fans are rubbing
    By tightwhitelx in forum 3geez Accords
    Last Post: 04-01-2003, 03:53 PM
  4. sway & anti-sway bars?
    By 89LXIGUY in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-24-2003, 07:31 PM
  5. tires rubbing
    By accordracerlx-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-03-2003, 10:45 AM
