Results 1 to 6 of 6
Thread: Civic Rear struts
    LXi User Jasonf860's Avatar
    Jul 2006
    89 Accord lx, 94 BMW 325i
    Question Civic Rear struts
    Ok, I did a whole bunch of searching.... Here are my questions:
    Once installed, are the spring perch heights the same as the accord? What I mean is, do these provide a huge drop with the factory civic springs or will I need to use a drop spring to get teh desired drop I want. I realize that these are much shorter than the Accord ones, but is it overall length and the perch is the same height, or is it the overall length and the perch also sits lower? Basically, what I'd like to know is if I put civic struts in the rear and some Tokico's in the front, both with my new Sprint 2.25" drop springs, will the rear be lower than the front?
    Jul 2006
    Re: Civic Rear struts
    Wow... no one knows?
    yes the rear will definitely sit lower then the front.
    Jul 2006
    Ok, so basically, I'd need stock Civic springs in the rear with my drop springs up front to get a closer ride height?
    Quote Originally Posted by Jasonf860
    No, you need to get coilovers to adjust all four corners to the proper height.
    Jul 2006
    Ah, I see. I have coilovers on the car now and they suck. I can't stand them and that is the reason why I'm changing my suspension yet again. It's at the ride height i want, and the handling is pretty good, but the ride just sucks.
  1. DIY: Front 1988-1990 Civic struts.
    By Legend_master in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-07-2012, 03:25 PM
  2. Civic Struts
    By Ju_S12_Turbo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-27-2009, 06:15 AM
  3. 1988-1990 Front Civic Struts Work
    Last Post: 07-11-2007, 11:16 PM
  4. Civic struts on 3G?
    By Soundy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-25-2006, 01:30 PM
  5. Working on a big what IF? 92+ civic 94+ teg struts on our cars
    By Jims 86LXI HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-18-2003, 08:57 PM
