Results 1 to 4 of 4
Thread: Idle Problem
    1988 Honda Accord Lxi
    Idle Problem
    Hey, I'm not sure if its a sensor or its just not be grounded right or what but... When I drive and then press it in the clutch at any speed it will idle down to 1,500. And it will only idle at 800 when i come to a complete stop... is it a vacuum leak maybe? I'm pretty sure its not But ya anyways can someone help
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: Idle Problem
    are you sure you hold the clutch pedal long enough.
    there is a diaphram that keeps the throttle from closing during shifts.
    hold the clutch pedal for longer than 10 seconds.
    Re: Idle Problem
    Ya like going down hills i hold it in or whatever and it just stays at 1500 never moves intill i come to a stop or release it is the diagfram thingy however you spell it on the intake? if so i will look for it tommrow
    Idaho
    Re: Idle Problem
    Quote Originally Posted by Fuzy Navel
    You could try adjusting your throttle cable on the Throttle body.
  1. accord lxi idle problem and start problem
    By sonusa in forum EFI Tech
    Last Post: 08-21-2006, 09:05 PM
  2. idle problem
    By AccordNut in forum 3geez Accords
    Last Post: 01-26-2005, 04:21 PM
  3. idle problem???
    By ltown lx-i in forum 3geez Accords
    Last Post: 11-18-2003, 02:05 PM
  4. Idle Problem?
    By Janiel in forum EFI Tech
    Last Post: 10-29-2003, 10:52 PM
  5. idle problem
    By XBLCanterX in forum 3geez Accords
    Last Post: 06-07-2002, 11:52 AM
