heres what happned i turned my car off to go in the house tried to turn car back on and not even a click no lights no nothing please help 1989 honda accord lx
Check your battery terminals for good contact, main relay, fuses.
prolly blew a main fuse somehow o.O
x2 mine dose it all the time im just to lazy to change the termanels they might just need to be cleand if u havent done it in a while or everOriginally Posted by ddude2uc
yup my terminal was lose so i just screwed it down...and it has worked....also be more specific on your tread titles.
i checked those and the battery is one month oldOriginally Posted by ddude2uc
do you get anything?
if you don't see any lights light up, your ground wire probably got broken or not making good contact.
also check the positive cable going to the fuse box.
If your 55 amp fuse is good & power to the fuse block. Check your ground as mentioned. Then if that is all good, using a test light, check to see if your getting power coming out of the ignition switch with the key turned in ACC & in crank position.
Try and see if your headlights come on. That tells you quick if your battery is any good or not.
today i took a wire and touched my negative term. on the battery and my car body and now it works again i walked to work all week 1hour there 1 backOriginally Posted by shepherd79
lol it's all good man, i remember one day i was working on my car and i was 1/2 way done, i shut the hood to go get something to eat, and i had only like 15 more minutes to work on my car,... well anyways i was yanking on my hood soo hard and freaking out, i simply forgot to pull the hood cable, lol. young and stupid, i know
I've moved on to bigger and better things. 94 integra Gsr Sedan is my new ride. And theres big things coming for it.
