I'm going to test/replace the choke pull-off diaphragm, which require removing the air cleaner box, removing several vacuum hoses. I want to buy some vacuum hoses just in case I need them.
My question is:
(1) What is the proper specs of the vacuum hoses on a 3G?
From what I've seen from MajesticHonda, 3.5mm diameter & 4.5mm diameter?
(2) Where to buy them?
Majestic charges like $30+, which is a little steep. I went to AutoZone & AdvanceAuto, they don't seem to have hoses that exactly the same as the original.
Any help is appreciated,
Thanks,
