Is this every thing I need for the swap?
Manual Transmission
Manual transmission mount
Shifter imitation leather boot
Shift linkage
Clutch cable
Flywheel
Driver’s side axle
Clutch pedal, springs, and switch
Brake pedal (manual ones are smaller)
(Whole pedal box highly recommended)
LX, LXi, and SEi came with cruise. pedals bolt to the brake booster
Gauge cluster (is it needed?)
Make sure you get a new clutch
Clutch number is 22105-PH4-A01
Get a new release bearing
Resurface the flywheel
Is there a difference in transmissions of the fi and carb manuals? or are they the same? The trans will come from a junk yard along with the pedal box what else should I grab? Also where can I get the rest of the parts
