Page 2 of 7 FirstFirst 123456 ... LastLast
Results 26 to 50 of 153
Thread: PROJECT: A20A to B18A Tranny Adapter Plate
    Jun 2001
    Boston MA
    Re: PROJECT: A20A to B18A Tranny Adapter Plate
    Quote Originally Posted by TWOLOUDNPROUD
    the crank space you can get them off auto a20a3 i have like two of them laying some where i would half to look for them
    i dont understand what you are saying. my a20a3 is auto, are you saing i can use something in there?
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    Jun 2001
    Boston MA
    yes, i will be using aluminum forthe plate. i am going to build the plate incase i blow up this tranny, it will make it esier to swap. no need to modify the end of the shiftlinkage, ill just use the whole integra shidter assembly. i already have an aftermarket b series tranny mount brack that ill weld insode the engine bay once i see exactly where the tranny will end up. as far as a xles go, one of our accounts for the towing company used to one silent drive, a axle company in boston. he now has a junkyard, ill ask him about shorthnig it or usring a different longer axle and shorthing that
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    Quote Originally Posted by SQ is the SQUAD
    On the a20a3 auto trany between the crank and the flex plate there is a crank space that what i am saying
    Jun 2001
    Boston MA
    if i have time today i am gonna pull off my auto tranny to see what your talking about
    Jun 2001
    Boston MA
    i took the auto tranny off earlier and the lil space that was in there was way too thin. it would tale 8 0f them to equal 1/2" but on the bright side i can use it as a trmplate for when i get my sheet of aluminum so that i can drill ome out. jason budd said that the longer bolts he used for thr flywheel are acutally arp bolts. the needed a lil shaced off the end, no biggie. just trying to see if i can get the part number
    Jan 2003
    1986 prelude
    charlotte nc
    some come on update us
    89T's Avatar
    Apr 2004
    well, i am still doing it anyways............................ just because i want to.
    are you done yet? j/k
    seems to be coming along well.
    un-motivated!
    3GR
  8. #33
    Jun 2001
    Boston MA
    everything is on hold until i finish moving into my sisters garage. no garage at my house
  9. #34
    LX User hondaman1986's Avatar
    Jul 2006
    86 hatch, and 93 maxima SE w /VE30DE
    clackamas
    hey man did you move yet or what!
    hows the adapter comming along?
  10. #35
    89T's Avatar
    Apr 2004
    Bringing this back from the dead.
    I know that life happens, but did you get any further with this project?
    un-motivated!
    3GR
  11. #36
    89T's Avatar
    Apr 2004
    So I am looking at h2b kits. Does anyone know if this h22 crank bolt pattern is the same as the a20. I am looking at the h2b fly wheel as possible answer to the spacer delema. If so all that is left is the transmission spacer. Now there could be a possible answer to that as well with the h2b transmission spacer.
    un-motivated!
    3GR
  12. #37
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    ^^^ im instead as well
  13. #38
    89T's Avatar
    Apr 2004
    I sent out some emails.
    un-motivated!
    3GR
  14. #39
    Feb 2012
    89/accord/lxi
    Im gonna go and by the wood to make a template. I have a b series trans and I'll just pull my trans and trace them both.
  15. #40
    89T's Avatar
    Apr 2004
    I got one email, they said they don't do 1 offs or even 10 offs. Lol
    un-motivated!
    3GR
  16. #41
    Feb 2012
    89/accord/lxi
    Wow. It ok just to sorry i can't help you sometimes. Lol i figured i would have to find a local shop to do it. I know a couple of places. I've also talked to chedda auto and he said he would ne will to do it for us. Not sure what yhe cost eould look like tho
  17. #42
    89T's Avatar
    Apr 2004
    Look at what i found! A Factory honda crank spacer.
    Lol.
    un-motivated!
    3GR
  18. #43
    Feb 2012
    89/accord/lxi
    Sick one step closer
  19. #44
    89T's Avatar
    Apr 2004
    I think I just figured out the b series clutch swap for the a20 trans. Think I'll keep that under wraps for now.
    un-motivated!
    3GR
  20. #45
    Feb 2012
    89/accord/lxi
    I see how it is
  21. #46
    89T's Avatar
    Apr 2004
    Have to test it
    first.
    un-motivated!
    3GR
  22. #47
    Have to test it
    first.
    They make shims for the flywheel as well I think there on Rockauto. That should get you dialed in.
  23. #48
    Feb 2012
    89/accord/lxi
    Welp it been year's since this was updated. But here you go. Also if you would like to get yourself one rech out will get a list going so as I test the plate in coming weeks.
    https://www.facebook.com/groups/3gee...5611320491415/
    Sent from my SM-N950U using Tapatalk
  24. #49
    Feb 2012
    89/accord/lxi
    Welp the first step in many to come. But the prototype has arrived and the spacer is on it's way. I'll source the need harder and go from there.
  25. #50
    89T's Avatar
    Apr 2004
    It should be there today.
    Sent from my SM-T800 using Tapatalk
    un-motivated!
    3GR
  1. 9 second a20!! a to b series tranny adapter plate!!
    By adams86lxi in forum Restoration & Custom Fabrication
    Last Post: 12-19-2019, 07:19 PM
  2. B18A Intake Manifold on A20A
    By bboipinoy112 in forum Performance
    Last Post: 09-12-2012, 05:53 PM
  3. B20a G.Box - Adapter Plate project!! Input needed!!
    By Tomisimo in forum Restoration & Custom Fabrication
    Last Post: 02-06-2009, 01:06 PM
  4. adapter plate , tubo manifold
    By newaccorddriver in forum Forced Induction
    Last Post: 02-23-2006, 07:23 PM
  5. B18A manifold -----> A20A head
    Last Post: 09-24-2003, 06:21 PM
