For the last year ever since the timing belt was replaced my engine just hasn’t been running strong. I’ve checked the timing and it appears to be fine… but I’m starting to thing that maybe the people who did the timing belt maybe had the cam jump a tooth or something? The only reason I think that is because I did something similar to that in my MR2, I accidentally skipped a tooth when I did my timing belt, and now my MR2 has now low end power, the power was shifted towards the top of the RPM range. Although in the accord, it seems to be a crappy powerband all around.
The engine revs freely when it’s in neutral… Once I get it in gear, the engine just doesn’t want to speed up… takes forever to get through the RPM’s and it feels like I’m dragging so much weight. I remember my old Accord being a lot better than this, so there is definitely something wrong here. Although the car does not feel that bad when you are light on the throttle, seems to go okay… but once you get on it, that’s when the car feels like its dragging some real weight. Does that make sense to any of you guys?
Another thing is that my clutch feels really weird, but it just started feeling this way recently. The clutch feels stiff at first, but once you get halfway through it, the clutch pedal just drops to the floor. As for the grabbing point… it has shifted up towards the top of the clutch pedal movement. Could this be a simple fix, or am I looking at replacing something?
This is an 89 Accord Coupe LX-i with about 180k miles on it now
TIA
Hopefully I can have it running nicely before winter truly hits here.
