So I've been researching ITBs for my Acura and have run into an area that affects anyone who wants to or is currently running ITBs, and that is the buildup of hot air in the engine getting sucked into the intake. Obviously for the drag racers out there it's not as big of a deal, but for longer track and backroad bombing the loss of power would probably be annoying. I'm posting this here because whatever we discuss here would be equally beneficial to anyone running an A20A with ITBs (All 1 or 2 of you )
Anyway I am trying to come up with a way to route cold air into the velocity stacks. I could just fab a cold-air system from the wheel well, but it seems like that would restrict airflow too much to be really beneficial.
Here is what I have come up with so far:
An airbox/heatshield assembly built around the openings of the velocity stacks that sits flush with the bottom of the hood, essentially sealing the air in that area from the rest of the engine bay. Air would then come in vented through a hole cut in the top of the hood a la the evo-style hood. A carbon-fiber or similar aftermarket hood would have to be used for this application. Obviously in street driving filters will have to be installed in the velocity stacks, but they should be there anyway.
Here are some extremely shitty diagrams I drew in Appleworks 6.
I think this setup is the most ideal for airflow and air temperature, but I am by no means an expert. The only problem is of course that when it rains you are essentially driving a car with a funnel running into the intake. So here is the main problem. How would one route air into the stacks in an efficient manner like this, but still keep water out?
