Page 39 of 49 FirstFirst ... 29353637383940414243 ... LastLast
Results 951 to 975 of 1219
Thread: The Journey 89 turbo'ed-----89T
  1. #951
    Re: getting started again. 89T
    More vids. And u saw my catch can setup?
    GO-AUTOWORKS Block Plug Adaptor D16 D15 DOHC ZC
    This will go in the rear of the block on our motor where the black box plugs in IF you cut off the first o-ring section and replace the o-ring with a smaller but fatter one.
  2. #952
    89T's Avatar
    Apr 2004
    Sweet , ill look into that. I am trying to take it easy for now. I went back and checked some notes and it turns out that the car only has 380 somthing miles since the rebuild. I am trying to get to atleast a thousand miles before dyno tuning.
    Sent from my SPH-L720 using Tapatalk
    un-motivated!
    3GR
  3. #953
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Can I get a ride? I'll bring the gopro down, and maybe I can get some nice shots. My buddy has been telling me go south and take a look at his boosted TL. Maybe we can get a little meet going?
    -Gio
    My E85 Turbo Build
    5280FEST
  4. #954
    Do that^^!!
  5. #955
    A Mile High.
    PM me your number, Jerry. I lost all my contacts a while ago.. I might even come down in my car Name:  ninja.gif
    -Gio
    My E85 Turbo Build
    5280FEST
  6. #956
    89T's Avatar
    Apr 2004
    Pm sent. Sorry for the late reply. I've been touring LA for the last week.
    un-motivated!
    3GR
  7. #957
    89T's Avatar
    Apr 2004
    No hondas in hollywood... wtf! Spent the day in Long Beach, insane only 2 Honda's hooked up dam.. lol
    un-motivated!
    3GR
  8. #958
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    Any updates on this beast?
    1989 Honda Accord LX-I 300K+
    Build Thread
  9. #959
    89T's Avatar
    Apr 2004
    She is just chill in in the garage. Nothing really going on. Starting to think the machine shop fucker up on the ring gap. There a lot of blow by.
    un-motivated!
    3GR
  10. #960
    Oh NOOOOO!!
  11. #961
    rings is n easy fix man. what does a leak down test say?
  12. #962
    89T's Avatar
    Apr 2004
    I'll have to do another leak down when I get some time. Just about ready to give up and tap out
    un-motivated!
    3GR
  13. #963
    please dont give up. you are my inspiration/goals to aim to beat
  14. #964
    89T's Avatar
    Apr 2004
    Lol. We'll see what happens.
    un-motivated!
    3GR
  15. #965
    89T's Avatar
    Apr 2004
    Well, I got a chance to do a compression test and leak down. Cold
    cylinder 1 170 psi plug dry black (rich) leak down 34%
    Cylinder 2 147 psi plug wet black "" 49% not sure if the wet plug means anything.
    Cylinder 3 157 psi plug dry black "" 43%
    Cylinder 4 160 psi plug dry black "" 42%
    What are your thoughts?
    un-motivated!
    3GR
  16. #966
    Not great, but not horrible either. Could you make it acceptable with some additional tuning?
  17. #967
    89T's Avatar
    Apr 2004
    I think so. It's blowing smoke under boost. It blows the dipstick out. lol! I am probably going to add additional vents to the valve cover.
    I think I am going to pull the head off and do a visual and throw on a fresh gasket.
    un-motivated!
    3GR
  18. #968
    SEi User
    Feb 2004
    Panama City, FL
    I had the same problem blowing the dip stick out, unfortunately for me it caused a fire when oil came out all over the exhaust manifold. I had two cylinders that only had 70 psi when I did a compression check so your motor is in much better shape than mine was. I'm planning on adding a tab on the side of my dip stick tube to hold the dip stick down, like some newer vehicles have on the transmission dip sticks, along with more crankcase ventalation to hopefully prevent the dip stick blow out.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
  19. #969
    89T's Avatar
    Apr 2004
    Right! I'll look into the tab deal too. I have a tig welder now , so I am looking into adding 4-10 an bung's to the Vc. If you need something let me know.
    un-motivated!
    3GR
  20. #970
    Having a good catch can would help the vent from pushing out the dipstick. Also A crank scraper would help.dont give up
    GO-AUTOWORKS D Series Block Fittings -10AN -12AN
    get rid of that oem oil separator and hook it up to a catch can.
  22. #972
    89T's Avatar
    Apr 2004
    I made that one way back, ended up not liking it. I am just being cheap. Lol
    un-motivated!
    3GR
  23. #973
    lol i remember that thing. Did you fill it with anything?
  24. #974
    89T's Avatar
    Apr 2004
    It was baffeled, I don't remember filling it with anything else.
    un-motivated!
    3GR
  25. #975
    89T's Avatar
    Apr 2004
    I finally got down and dirty today!
    I figured I'd give this a try. . Hope fully it will solve my blow by issue.
    un-motivated!
    3GR
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. My MPG Journey
    By soonerck in forum EFI Tech
    Last Post: 03-18-2011, 08:58 AM
  3. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  4. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
