Page 40 of 49 FirstFirst ... 30363738394041424344 ... LastLast
Results 976 to 1,000 of 1219
Thread: The Journey 89 turbo'ed-----89T
  1. #976
    89T's Avatar
    Apr 2004
    Re: getting started again. 89T
    I got it all welded up today. I have to do some cleaning and take care of a few odds and ends before I reinstall it. I went the cheap way to see if it will work, If it does I will use good fittings and braded line.
    un-motivated!
    3GR
  2. #977
    ohhh nice!!!
  3. #978
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Let me know how the exhaust valves work for you. I still have one rolling around in the garage that I never installed.
  4. #979
    89T's Avatar
    Apr 2004
    Will do. I had to make a new motor mount, there's hardly any room for anything.
    un-motivated!
    3GR
  5. #980
    89T's Avatar
    Apr 2004
    Re: The Journey 89 turbo'ed-----89T
    Well I got it done today but its f****** dirty. I've remounted my front bumper cover so that's it straight. Like I said this is just a trial run. We will see how it works once the snow melts. She hasn't seen a day of rain or snow in like 5-6 years.
    Also I had my 2 threads merged and renamed. My first thread when I was doing the Ford distributor as 89Turbo'ed and my newer thread getting started again 89t.
    un-motivated!
    3GR
  6. #981
    89T's Avatar
    Apr 2004
    So I finally got around to finishing up that strut bar that I started way back. Lol
    No frills, just simple.
    un-motivated!
    3GR
  7. #982
    My man! Make me one now lol.
    Why did you choose those holes to mount to?
  8. #983
    89T's Avatar
    Apr 2004
    I used the front most shock tower bolt and the rear upper control arm bolt. I felt that most of the stress is at the upper control arm and not so much at the shock tower. Although if I can spread the mounting points further apart it would strengthen the area between the two mounting points aswell as tower to tower. This would make for a more rigid front end.
    I am fighting my self on a traction bar. What we have from the factory works. It may be a little heavy but it works. I don't like the angle of the radious rod,(I guess that's what it's called) it could be moved up on the front to better plant the tires on a launch.
    What I am looking at is a little different. As you can tell I like different. I want somthing simular to a ladder bar or a 4 link. It is in thought presses right now.
    un-motivated!
    3GR
  9. #984
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    I've been try to get chedda to make us t-bar for a while now. I think it would help the most as far as traction go's. It's also more cost effervescent not to mention the wight you'll save. My goal is to get my car under 2400 pounds. That would make it less the any full size Honda a 100 pounds more then a eg. With the right power numbers you'll be more evenly matched.
  10. #985
    89T's Avatar
    Apr 2004
    Last time I scaled I was at 2400ish with me in the car. So about 2240ish. I could easily drop another 100 - 150# if I got down and dirty.
    I also think to do a good t-bar it would need to be a double bar with gussets or plates between them.
    As far as power numbers between the a20 vs b18 counter part, we can out torque the b18 but I am not so sure on the top end.
    If you can rev high and 60 foot, I see no problem wining races. My best 60 foot was a 1.8 and if I can get it into th 5 s and manage more top end power ... man I'd be in like flyn.
    un-motivated!
    3GR
  11. #986
    Oh I see now, I wonderd what I was looking at in the first pic, seems like it will tighten up the front box good like that!
  12. #987
    89T's Avatar
    Apr 2004
    I wanted to put in a couple more braces, but I decided to keep it basic.
    This what I kinda envisioned for a 4 link. It's not to scale its just a rendering.
    un-motivated!
    3GR
  13. #988
    Feb 2012
    89/accord/lxi
    Nice
  14. #989
    89T's Avatar
    Apr 2004
    I got to thinking, another thing that needs to be done is either super hard bushings or solid aluminum bushings.
    un-motivated!
    3GR
  15. #990
    89T's Avatar
    Apr 2004
    I tested the crankcase evacuation valve today. I got mixed results. It's still pushing the dip stick out but it is smoking alot less under boost. I ended up only doing 1 . From what I am reading you should not run a muffler with the valve do to back pressure in the exhaust. So I think I am on the right track . I either need to remove my nice quiet muffler and add another valve or spend 500 on a proper catch setup. On a side note it was smoking a bit so I decided it was burning excess build up off. We went out for a cruise and 15 minutes later it cleared. I got home and quickly realized that I forgot to plug in the fan. I watched the temperature the entire time we were out and it never got hot . although after shutting it off coolant started coming out right around the filler neck. I can't win. Lol..
    un-motivated!
    3GR
  16. #991
    why for link? and sucks man. we cant do anything fun in these cars without something dumb happening. just spend the $500. get it right now
  17. #992
    89T's Avatar
    Apr 2004
    Why the 4 link yousay. Idk I just like to make things complicated I guess.
    un-motivated!
    3GR
  18. #993
    bump. Show us some more cool pics.
  19. #994
    89T's Avatar
    Apr 2004
    Such as?
    un-motivated!
    3GR
  20. #995
    make something.
  21. #996
    89T's Avatar
    Apr 2004
    Lol.still have to get filler rod and lenses.
    un-motivated!
    3GR
  22. #997
    89T's Avatar
    Apr 2004
    Here Tim. The cool pick of the day!
    un-motivated!
    3GR
  23. #998
    hey look, a box!
  24. #999
    89T's Avatar
    Apr 2004
    A multi - surface aluminum box!
    5 quarts at that..
    un-motivated!
    3GR
  25. #1000
    sweet ur making a in car cooler for ur track beers??
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. My MPG Journey
    By soonerck in forum EFI Tech
    Last Post: 03-18-2011, 08:58 AM
  3. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  4. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
