Page 45 of 49 FirstFirst ... 35414243444546474849 LastLast
Results 1,101 to 1,125 of 1219
Thread: The Journey 89 turbo'ed-----89T
  1. #1101
    89T's Avatar
    Apr 2004
    Re: The Journey 89 turbo'ed-----89T
    Thanks
    un-motivated!
    3GR
  2. #1102
    89T's Avatar
    Apr 2004
    Did some stuff today
    un-motivated!
    3GR
  3. #1103
    89T's Avatar
    Apr 2004
    un-motivated!
    3GR
  4. #1104
    hell yea! get it done!
  5. #1105
    89T's Avatar
    Apr 2004
    You bet.
    I'll leave these here.
    un-motivated!
    3GR
  6. #1106
    Mad scientists over here!
  7. #1107
    89T's Avatar
    Apr 2004
    Mad as hell, like Jekyll and Hyde
    un-motivated!
    3GR
  8. #1108
    89T's Avatar
    Apr 2004
    Here you go tim... making a jig for a solid rear mount...
    un-motivated!
    3GR
  9. #1109
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Ohhh yea. I am not sure what is going on with the trans-axle but the progress is looking good man!
    Andrew.
  10. #1110
    89T's Avatar
    Apr 2004
    I am removing the front mount all together. The plate will become the new side mount. There was nothing on the transmission that was strong enough to mount to. So this is the best alternative.
    un-motivated!
    3GR
  11. #1111
    Ohh a jig... i see you!
  12. #1112
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    No more messing around I see!
    So what are you going to do with all that glorious space now?
    Andrew.
  13. #1113
    89T's Avatar
    Apr 2004
    For now the plan is to clean it up.
    un-motivated!
    3GR
  14. #1114
    89T's Avatar
    Apr 2004
    Solid rear mount.
    un-motivated!
    3GR
  15. #1115
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Looking good!
    I can't recall if you got your motor back from the shop all sorted out yet or not? Is the motor your test fitting to an extra block or the original one you were getting repaired?
    Andrew.
  16. #1116
    89T's Avatar
    Apr 2004
    That's the old block. I got a "new to me" block and had it machined. I got it back last Wednesday. I just want to sort out the mounts and such before I put it together.
    un-motivated!
    3GR
  17. #1117
    89T's Avatar
    Apr 2004
    Okay so. Bandsaw blade broke again. So I stopped working on on the motor mounts. I decided to see what was wrong with the clutch seeing that I have the old motor and transmission mocked up.
    So from 0 with the clutch fully depressed I've only got 1 5/16 inches of travel. Now from where I had the clutch adjusted to originally at full disengagement is an additional inch and a half past that 1 5/16 inch. Meaning that I need 2 13/16 of travel. So what I'm getting at is WTF. Will Somebody go out and measure those for me.? The Only real solution that i can seeI at this point is relocating where the clutch cable connects to the armature to about halfway down the armature.
    un-motivated!
    3GR
  18. #1118
    89T's Avatar
    Apr 2004
    This is about how much more pedal movement I need.
    un-motivated!
    3GR
  19. #1119
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    I'd have to check mine to see if its similar at all.
    I do notice though that compared to stock, the integra cable has less travel in it all together, I pretty much have it at max adjustment and there is enough pedal to shift normally but maybe 1/4 less than stock(pedal movement). Anyway, what I am getting at is that stock will probably be a better option to go if you need the most pedal travel you can get(I can't remember which you have, sorry).
    Andrew.
  20. #1120
    89T's Avatar
    Apr 2004
    I have the clutchnet red clutch and pressure plate with the aluminum flywheel
    I also have the stock clutch cable
    un-motivated!
    3GR
  21. #1121
    your cable might be going bad, replace that fucker. they are like 20-30 for a brand new one from autozone.
  22. #1122
    89T's Avatar
    Apr 2004
    13 bucks. I'll pick one up!
    un-motivated!
    3GR
  23. #1123
    even better. when mine came uncrimped and almost left me stranded a mile from my house -_-
  24. #1124
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Man that's affordable, I don't think I could get a price like that around here! Mind you, I don't think I could have piece of mind with a $13 cable doing an essential part of driving.
    I hope that solves the problem though.
    Andrew.
  25. #1125
    89T's Avatar
    Apr 2004
    13 bucks and it was the only one in town. I'll take it! I hope that's it though.
    un-motivated!
    3GR
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. My MPG Journey
    By soonerck in forum EFI Tech
    Last Post: 03-18-2011, 08:58 AM
  3. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  4. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
