Results 1 to 16 of 16
Thread: A20 Turbo Header
    DX User josephgilpin's Avatar
    Nov 2006
    89 Accord DX
    North Carolina
    A20 Turbo Header
    I have searched and searched and i need help if there is no head swaps can any of you tell me were i can get a turbo header or a honda turbo header that will fit on the A20 Head
    Re: A20 Turbo Header
    the only thing close that would be able to fit would be the f22 header...but even that you will have to cut up and weld...A20A1 has a write up on f22 headers for our block so a turbo mani would almost be the same... you can get some manifolds custom made....i think justin86 make em but right now he is trying to sell his own turbo kit.
    heres a whole turbo kit. All ready to go.
    Nov 2002
    Ridin Dirty in New York
    you either need to buy somebodys that has been custom made or make your own. Nobody makes one
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    There is also a remote mount turbo setup that bolts to the exhaust or one that uses the header and bolts the the A pipe of the header in a remote location in the engine bay... like where the battery is.
    Vanilla Sky's Avatar
    1999 Penalty Box
    you're carbed... you have lots to learn. forced induction with our carbs is pretty much useless. don't bother.
    shepherd79's Avatar
    Falling Waters, WV USA
    you want turbo header, here it is. get ready to spend $750 plus shipping on something your car won't be using. http://www.evolution-racing.com/store/exmanifold.htm
    get EFI car. turbo on carb engine is just asking for problems.
    Nov 2006
    89 Accord DX
    North Carolina
    Thanks guys for lots of help on finding a turbo header
    i found a guy here were i live that is macking me a carb hate tubo bonnet
    so i can run a turbo through a carb.
    yyyyyyeeeeaaaaahhhhh
    race12001's Avatar
    Sanford NC
    just convert to efi that would be better than carb plus you can tune it as you adjust your boost
    Dec. 05-Dec. 06
    Nov 2006
    i have a 83 prelude would it be worth it to convert it to fuel inection and turbo or no?
    shepherd79's Avatar
    Quote Originally Posted by josephgilpin
    first time you hit the boost that engine is going to BLOW. take a video of it. I want to laught out loud when i watch that video.
    A20A1's Avatar
    Sep 2001
    What about your fuel pressure? if you don't increase fuel PSI in relation to boost you'll push all your fuel back out the carb or plug it up at the least. Also the stock float is plastic... it can break under boost pressure.
    shepherd79's Avatar
    like I said, take a video of the engine blowing up.
    josephgilpin, i hope you know what you are doing, because the way you sound you have no freaking clue how to get around engine bay are or do any major mods.
    If you are going with turbo on your carb accord, you will need to upgrade: 1. carb with WEBER at least. 2. fuel pressure, the pressure has to be above the boost you are going to run. 3. find someone who can tune the weber or the carb you are going with so it won't lean out on you.
    those are just BASIC things you need to do to keep the car somewhat running.
    Quote Originally Posted by fredster102
    depends how the condition of the car....if not save up money and get a fuel injected 5 speed and then turbo
    easiest way to turbo a carbed car is a pull-through setup, just get a bigger CFM carb and you won't have to worry about the fuel pressure changes and the special floats. The stock carb can barely feed the stock motor. I am thinking of going this route myseld if I can't get a good deal on an ECU. It's a cheap alternative, maybe not as efficient as a blow-through but it works
    Eric
    Nov 2006
    my cars in good condition i can get the conversion done cheap too but would it be worth it and what other mods would i need
  1. Turbo 3G role call... Paging turbo'ed guys
    By AccordEpicenter in forum Forced Induction
    Last Post: 06-07-2011, 11:26 AM
  2. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  3. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
  4. F/S Charge pipes and turbo header
    By 88turboaccord in forum Trading Post
    Last Post: 08-31-2003, 08:21 AM
  5. Got my DC header, 2 1/4" piping, no cat, and Borla turbo installed.
    By Shin87LXI in forum Classic Honda Community Chat
    Last Post: 03-25-2003, 04:25 PM
