HERE'S A SNEAK PEAK AT THE MAP LIGHT LED CIRCUIT BOARD I WILL BE PUTTING INTO PRODUCTION. THERE WILL BE MORE WHITE LED'S OF COURSE. I WILL PROBABLY PUT 8 IN EACH SIDE.
ALSO, THIS IS BASICALLY HOW I WILL BE DOING THE TAIL LIGHTS EXCEPT WITH 10MM WHITE LED'S...BWA BWA BWA!
ALSO, THIS IS BASICALLY HOW I WILL BE DOING THE TAIL LIGHTS EXCEPT WITH 10MM WHITE LED'S...BWA BWA BWA! I WILL BE PUTTING PROBABLY 4 ROWS IN EACH HOUSING WITH A TOTAL OF 50 OR SO LEDS EACH HOUSING. I USED RED 5MM DIFFUSED LEDS FOR THIS PROTOTYPE SINCE THEY ARE CHEAP AS HELL TO BUY.
