View Poll Results: Vote for the best hatchback/aerodeck
Voters
31. You may not vote on this poll
  • BITESIZE
    5 16.13%
  • Vinny
    0 0%
  • Paul Aerodeck86
    4 12.90%
  • guaynabo89
    13 41.94%
  • Hondaman87
    2 6.45%
  • LegendMaster
    4 12.90%
  • Bullard123
    3 9.68%
Results 1 to 8 of 8
Thread: ROUND 1 Accord of the Year Voting - Hatchbacks & Aerodecks
    87accordlxi's Avatar
    Oct 2000
    Here are our AOY nominees in the Hatchback/Aerodeck class. Please take your time in choosing the best vehicle. There are a number of pictures in this thread, and they may take some time to load, even on fast connections. The winner of this poll will continue on to the second round and face the best sedan and best coupe winners.
    Just as in the AOM voting threads, THERE IS NO POSTING ALLOWED IN HERE. JUST VOTE.
    This poll closes on December 15th.
    - Joe
    Oct 2000
    Re: ROUND 1 Accord of the Year Voting - Hatchbacks
    BITESIZE
    AOM Winner: May 2004
    Nominated by 88accordhatchdx
    EXEL H-50 17" RIMS W/ KUMHO 205.40 TIRES
    EIBACH SPORTLINE 1.5" DROP SPRINGS
    TOKICO STRUTS/SHOCKS
    2.25 DEGREE FRONT LES SCHWAB CAMBER KIT
    POWERSTEERING RACK AND PINION
    2 - POWER STEERING HOSES
    2 - BATTERIES W/WARANTY
    4 - ALTERNATORS W/WARRANTY
    2 - RADIATORS
    COMPLETE FRONT BRAKES
    COMPLETE REAR BRAKES
    PCV VALVE
    ENGINE GASKETS
    THERMOSTAT
    FUEL FILTERS
    SPARK PLUGS, CAP, ROTOR
    SPARK PLUG WIRE HOLDERS
    2- RED HOSE KITS
    2 - OXYGEN SENSORS
    ALL ENGINE/TRANSMISSION MOUNTS
    5 SPEED TRANSMISSION SWAP W/CLUTCH
    5 SPEED CONVERSION COMPONENTS
    ECU
    SHIFT LINKAGE
    AXLE
    PEDALS/SWITCHES
    10 MM RED SPARK PLUG WIRES
    INTEGRA CUSTOM COLD AIR INTAKE
    PACESETTER HEADER
    MUFFLER
    2.25 INCH FULL STRAIGHT PIPE EXHAUST
    20% TINT ALL AROUND
    PIONEER CD PLAYER
    DVD/MP3 PLAYER
    PYRAMID 7.5" SCREEN
    FM MODULATOR
    FOSGATE 400 WATT AMPLIFIER
    RADIOSHAK BASS CROSSOVER
    ECLIPSE 12" 1000 WATT SUBWOOFER
    12" BANDPASS SEALED BOX
    4 - 6.5" KENWOOD SPEAKERS
    AMPLIFIER WIRING KIT
    FIRE EXTINGUISHER
    BLACK / RED FLOOR MATS
    AUTOMETER GAUGES
    AIR FUEL RATIO
    OIL PRESSURE
    VOLTAGE
    ENGINE TEMPERATURE
    TENZO SHIFT KNOB
    NOKYA EBRAKE HANDLE
    EUROLITE HEADLIGHTS W/ BULBS
    NIGHTSHADE TINT (TAIL LIGHTS, FRONT LIGHTS)
    SIDE MARKER LIGHTS
    1st place bracket racing
    - Joe
    Oct 2000
    Vinny
    AOM Winner: October 2004
    Nominated by NXRacer
    Suspension
    H&R Sport Springs lowering the car 1.5”
    Koni Special (red) Dampers on all corners
    DC Front Strut Bar
    ADDCO Front and Rear Sway Bars
    Ingalls Camber kits, front and rear
    ADR Sokudo 17”x7” wheels in Light gun metal. Wrapped with 205/40/17 Ventus HR II’s
    Performance
    AEM CAI Modified to fit
    DC Sports Header
    Colt Tri Flow Cam
    2.25” Exhaust tubing, 36” resonator, flowing to a turbo muffler with a straight cut tip
    MSD 6A ignition with MSD Blaster SS coil
    NGK Iridium Plugs
    SE-I Rear disc Brake conversion
    Techna-Fit stainless lines
    Appearance, Interior
    Indiglo Gauges
    Carbon Fiber Bezel
    SE-I Armrest and cup holder
    Appearance, Exterior
    Erubini Front Bumper Cover
    JDM Corners
    windows tinted 20%
    Carbon Fiber Hood
    Stereo
    Clarion Pro Audio HX-D10 Head Unit
    Clarion SIRCL1 Sirius Tuner
    Clarion Pro Audio DCZ625 CD Changer
    HiFonics Jupiter Series VIII Amplifier 4x35w
    HiFonics Vulcan Series VIII Mono Block Amplifier 100Wx1
    Pioneer TS-A1670R 6.5" 3-way Speakers
    2 Power Acoustik 12's
    - Joe
    Oct 2000
    Re: ROUND 1 Accord of the Year Voting - Aerodecks
    Paul Aerodeck86
    AOM Winner: November 2004
    Nominated by Justin86
    Performance
    Custom Air Intake with Honda S2000 Air Filter
    CENTERFORCE Dual Friction Clutch
    APEXi REV/SPEED Meter
    Handeling
    KONI Red Special Adjustable Absorbers
    H&R Stage 2 Springs 1.5" drop
    CHROME Concept Neeper Syncros R16 Rims
    205/45/ZR16 TOYO JDM Tires
    Apperance
    Carbon Fiber Lightweight Hood hot!
    Red Honda Type-R emblems
    HELLA Side Markers (uninstalled)
    Custom ALUMINIUM Grill Mesh (temporairy uninstalled)
    Low Beams: HID Conversion: Philips D2S 35w lamps and HELLA Ballast Systems
    Hi Beams: HID Conversion: Hella Micro DE fogs (not installed yet)
    DiamondBack Headlight Conversion
    Ice
    CLARION 13cm Front 200W Speakers
    CD-Receiver temporary removed
    If you have not yet seen Paul's site you should definitly check it out.
    http://www.pauldesign.ru/
    - Joe
    Oct 2000
    guaynabo89
    AOM Winner: February 2005
    Nominated by 88LXi68
    ENGINE
    - 30 over 10 to 1 comp pistons w/ total seal rings
    - crower rods
    - jg head
    - jg t.b.
    - jg cam (race)
    - port matched intake manifold
    - aluminum valve spring retainers
    - aluminum flywheel
    - underdrive pulleys( all pulleys)
    - adj cam gear
    - custom fuel rail
    - venom injectors
    - stillen fuel regulator
    - msd 6al
    - msd blaster ss
    - magnacor wires
    - custom c/a/i with bypass valve
    - b&m oil cooler
    - centerforce clutch
    - engine completely rebuilt and balanced
    - optima battery
    EXHAUST
    - DC header (wrapped)
    - random tech cat
    - 2 1/4 mandrel bent exhaust with remus style muffler
    Suspension
    - Niche multipiece shocks painted to match
    - Sprint spring 2.25" drop
    - Koni Dampers on all corners
    - camber kits
    - suspension techniques sway bars
    - dc strut bar
    - rear upper strut bar
    - rear disc brake conversion
    - aem big brake kits(front and rear)
    - kvr carbon kevlar pads
    - stainless braided brake lines
    Exterior
    - piaa driving lights h4 conversions with piaa extreme whites custom spoiler and front lip much body parts shaved custom sunroof
    Interior
    - Custom Leather interior
    - two-tone leather with reclining racing seats
    - Momo Combat Evo Shifter in carbon
    - Momo Challenger Pedals
    - Momo Pit Stop E brake handle in carbon
    - Custom power door locks with molded switches
    - Joe
    Oct 2000
    Re: ROUND 1 Accord of the Year Voting - Hatchbacks & Aerodecks
    Hondaman87
    AOM Winner: March 2006
    Nominated by bullard123
    1987 Honda Accord DXE-i
    silver and black
    Engine
    Engine: A20a3
    excell 8.8 wires (sized to fit )
    excell Blast coil
    Custom made cam adjuster
    Polished valve cover
    Polished intake
    Custom made cold air intake
    Painted engine (black and gun metal grey)
    Painted trans. (gun metal grey)
    Suspension
    Bigger front brake from an 89 Honda accord SEI
    Rear disc brake conversion from an 89 Honda accord SEI
    Skunk 2 racing coil overs
    Custom made front and rear strut bars
    Stock shocks
    Painted calipers (silver)
    Exterior
    Custom made reverse hood scoop (no inserts)
    Custom made Z3 fenders (no inserts )
    Custom made 1/4 scoops from a 98 Trans am fenders
    Rear wing from 87 Toyota supra
    Front bumper from a 93 honda accord
    Rear bumper from a 93 Honda accord, in which it was, reduced 4 inches in the sides
    Side skirts from a 92 Chevy cavalier Z24, in which it was added 1/2 inch on the side skirts and 2 inch on the door molding
    Modified rear taillight from original to clear
    Modified front side markers from original to clear
    Reflective decal symbolizing the Honda motorcycle gull wing gull wing decal
    Reflective NEX-GEN decal
    Custom made front and rear splitters
    Polished jdm power folding rear mirrors
    Fitted pop up sun roof
    ICW Racing 18x7 wheels
    215/35/18 BFGOODRICH Scorches tires
    Exhaust
    Pace settler headers
    Straight pipe
    2 chamber FLOWMASTER
    5 inch BROSPEED tip
    Interior
    custom fitted B and C pillar bar
    Custom made white gauge cluster
    Seats from 89 Isuzu impulse
    2 tone interior door panels, dash, and center council
    Racing style rear view mirror
    13 inch Grant steering wheel
    Auto meter gauge pod 2 ports 2 1/16 size
    Auto gauge tack
    Auto meter oil press gauge
    Auto meter volts gauge
    Corbeau seats Four point hardness
    Sound
    Sony xplod CD player
    Bose speakers all around
    MTX Blue thunder Pro 752 2 channel amp
    JBL Gtq 190 4 channel amp
    HI WAVE 1.5 farad cap.
    2 12 inch MTX Road thunder single reflex band pass subs
    Lighting
    7 colors led under body lit
    98 BMW M3 clear side markers
    H4 headlight convention
    04 Cadillac escalade HID head light kit
    04 KIA spectra fog lights (used as driving lights and also signal)
    Front strobes mounted in the fog lights
    Awards:
    1) 3rd place for import tuner honda @ world of wheels
    1) 2nd place for best 2 door wild @ currys audio
    1) 3rd Place Mild 2 door @ 05 Import Evolution 4
    2) 2nd place for best old school @ 05 import wars for the honda class
    1) 1st place show class winner @05 import wars for the honda class through 1993
    - Joe
    Oct 2000
    LegendMaster
    AOM Winner: April 2006
    Nominated by gfrg88
    1986 Honda Accord Hatchback
    Motor
    1.8L LS/Vtec
    1991 B18a bottom end
    Stock pistons bored .20 over
    ARP head and rod bolts
    Fully balanced/shot-peened and all parts were coated
    New GSR/R Fuel pump and water pump
    Lightened flywheel
    GSR head Milled just a little
    Cosmetic thin head gasket
    STR Cam gears
    AEBS intake manifold with stock GSR TB
    Ebay Megan racing header modified with a 2.5 Collector
    Full exhaust all the way back to a gt v6 Eclipse Muffler
    Front Suspension
    89 LX-i hubs (must be 88-89 LX-i Hubs) with new bearing
    11" Acura Legend rotors Redrilled to 4x100 from a 1989 Acura Legend
    1998 Acura integra Type R Calipers and the brake pads that came with them (no bracket Required)
    Full Prothane Poly Bushings for the Lower control arm and OEM for the rest
    SS Steal braided brake lines all around
    ARP extended Wheel studs (just because I wanted to)
    Suspension Techniques 2.5" springs
    1990 Civic Tokico Illuminas
    Suspension Techniques front sway bar.
    1988 Prelude 35/40 prop valve
    all ball joints and tie rod ends.
    Rear Suspension
    Sei Rear disk brake Convertion
    1988 Acura Legend Rear Calipers
    Drilled and slotted EBC rotors
    EBC green stuff brake pads
    Suspension Techniques rear sway bar
    Exterior
    88-89 coupe front bumper swap
    Modified 89 Acura Integra Front Lip
    - Joe
    Oct 2000
    Bullard123
    AOM Winner: August 2006
    Nominated by jigga225
    1988 Honda accord Lxi
    Exterior
    Fiberglass Z3 fenders
    90-93 integra full body kit
    black widow front bumer
    spiderman side skirts
    spiderman rear
    Toyota scion hood scoop (custom)
    Jdm sidemarkers
    Carbon fiber wiperblades front and rear
    custom clear/red tails
    H4 headlight housings
    custom two tone paint gunmetal / silver
    w/gold pinstripe
    shaved side mouldings
    tinted windows
    Drag 17x7 Jdm rims gunmetal w/polished lip
    205/40/17 Wanli tires
    Interior
    Racing black/gray seat covers
    painted interior black/gray
    carbon fiber floor mats
    "H" symbol on dashboard
    Engine
    A20A3 FI engine
    Weaopn R short ram intake
    NGK Oem sparkplug wires
    Toucan oil air breather
    Nippon Denso U groove spark plugs
    Koyo High flow radiator (soon to be installed)
    Exhaust
    Dual exhaust
    2 stainless steel dual tip high flow mufflers
    2.25 in piping
    Suspension
    Sprint 2.25 in lowering springs
    Tokico struts
    Camberkits
    - Joe
  1. Accord of the Year Voting - 2009
    Last Post: 12-06-2009, 04:37 PM
  2. ACCORD OF THE YEAR Voting - 2008
    Last Post: 11-28-2008, 09:01 AM
  3. ACCORD OF THE YEAR Voting - 2007
    Last Post: 12-03-2007, 06:12 AM
  4. ROUND 1 Accord of the Year Voting - Coupes
    Last Post: 11-28-2006, 08:59 AM
  5. ROUND 1 Accord of the Year Voting - Sedans
    Last Post: 11-28-2006, 08:56 AM
