Results 1 to 5 of 5
Thread: Nominations for January 2007 Accord of the Month
    87accordlxi's Avatar
    Oct 2000
    Its time to nominate your favorite ride for AOM: January 2007
    Check out the Rules & Regulations
    How to Nominate a Vehicle for AOM
    All winners in the past year are ineligible for nomination:
    January 06 - AccordEpicenter
    February 06 - Jigga225
    March 06 - Hondaman87
    April '06 - Legend Master
    May 06 - carotman
    June 06 - WickedAccord
    July 06 - 88LXi68
    August 06 - Bullard123
    September 06 - Toneloc5145
    October 06 - Cheeseburger
    November 06 - TWOLOUDANDPROUD
    December 06 - mymonkey
    Members must have 50 posts in order to nominate someone
    Duplicate nominations will be deleted
    Posts made that are not nominations will be deleted
    Invalid nominations will be deleted
    There is no need to second a nomination! If a nomination is valid, it will proceed to the voting stage automatically.
    - Joe
    Re: Nominations for January 2007 Accord of the Month
    I'd Like to Nominate:
    Picopop
    Engine Specifications:
    * Stock A20A3 2.0 FI
    NGK Iridium Spark Plugs
    NGK Wires
    MSD Blaster 2 Coil
    Bosch 70 amp Prelude Alternator
    91 Integra CAI
    CR Performance Battery Ground Upgrade Kit
    Exide Orbital Battery
    20/50 Royal Purple Synthetic Oil
    Exhaust:
    * 2.25 Pipe from the cat. back
    Magnaflow Muffler
    Stainless Steal Tip
    Drivetrain:
    * Automatic (for right now)
    Suspension, wheels & tires:
    * Proline 478 Rims 15x6.5
    Kumho ECSTA 711 tires 195-50/15
    Kumho ECSTA AST 205-50/15
    KYB GR-2 Shocks Front
    Tokico HP Shocks Rear
    Trustar ceramic brake pads
    Brembo rotors
    Justin Front Strut Bar
    Justin Rear Lower Bar (not installed yet)
    H&R Sport Springs 1.5 Drop
    Interior:
    * OE foglamp switch
    SEI Armrest
    SEI Cupholders
    Black and Burgandy Interior (Black dashboard, Upper Door trim black to match dash,Black Center Console and Armrest, black accents thru out the car)
    Ice
    * Deck:Alpine CDA-9851
    Doorsual 6.5 2-way Speakers XP65i
    Rear:Kenwood KFC-6959ie 6"x9" 2-way Speakers
    Boom:Xs-l102p5 10" Xplod Subwoofer
    Box:Q-Logic Single 10 QLH-.6510SS sealed box
    Power: Profile AP400 65ws x 2 Car Amp bridged to the sub woofer
    Satelilite:Alpine XM Direct Adapter
    Exterior:
    * Hella H4 Headlamps
    Sylvania SilverStar Bulbs
    Pilot L.E.D. Side Marker Bulbs
    JDM Corner Lamps
    Clear Turn Signals
    SilverStar Turn Signal Bulbs
    89 Integra front lip
    Hella Optilux 1100 Fog Lamp Kit
    Coming Soon
    * 5 speed swap
    High Flow Cat. and Resonator
    Brembo X-Drilled ft Disc
    SEI Rear Disc Swap
    Complete Rebuilt A20A3 Engine (20-30 bore)
    Justin Rear Strut Bar
    * CarDomain
    http://www.cardomain.com/id/picopop
    [/QUOTE]
    I'd Also like to Nominate:
    thegreatdane
    Honda Accord 2.0i-16 1987
    Engine:
    * H22A DC Sports header, modified to fit and ported to match B20A ports. Collector replaced with a 2.5" collector instead of that pos 2" they are made with
    * 2.5" custom stainless exhaust straight through with a Simons silencer and a Magnaflow muffler
    * B16A2 intake manifold
    * B18B distributor and custom block-off plate at exhaust cam
    * B&M fuel pressure regulator
    * JDM B20A cams
    * Valve cover painted white
    * Black box removed
    Fuel & Tuning:
    * Converted to OBD1
    * P06 ecu converted to P28 and chipped
    * Boomslang 3rd gen Accord OBD0->OBD1 conversion harness
    * VSS sensor 6k resistor mod
    * Ostrich rom emulator
    * USB datalogging
    * Innovate LM1 wideband
    * Crome Pro tuning
    * Koni red struts front and rear
    * Ground Control coilovers
    * DC sports front strut bar painted white (not installed currently, there's no room for it with the B16A2 manifold)
    * 17x7" Kosei Sniper rims w. Falken tires.
    Interior:
    * Digital gauge cluster from RHD CA3 Accord
    * Auto-Up drivers side window switch mod
    Exterior:
    * New paint job in summer 2005
    * JDM power folding mirrors painted silver like the car
    * JDM CA headlight turnsignals - replaced the ugly dummy lense reflector
    * Removed small round front fender turnsignals
    * Door handles painted silver like the car
    * Badboy look welded to the bonnet
    Parts in store but still waiting to get installed:
    * '88-'89 Vigor taillights (need to fabricate custom trunk lid since I have to use a regular '86-'87 lid)
    * '88-'89 USDM bumpers with clear turnsignals (waiting for the rear bumper)
    * '88-'89 Xenon bodykit
    * Pacesetter short shifter
    * Crower stage 2 cams, shortened approx. 5mm at the camgear ends (already drove the car with them in, but the engine died shortly after so they are out at the moment)
    * and other stuff I forgot about
    MessyHonda
    1989 Honda Accord
    3g project
    Lx-i
    Stock A20A3 with 140k
    Custom Adjustable Cam gear
    koyo High flow radiator
    Teg 90-93 red CAI
    MSD blaster 2 coil
    Crane 11mm red wires
    NGK v-power plugs
    Coming soon:
    DC headers 4-2-1
    MSD 6AL ignition box
    4g map sensor
    Bored out TB
    Drivetrain:
    5 speed manual
    new clutch at 113k
    Coming soon:
    Custom Short Shifter with poly bushings.
    new Reman axels.
    Exhaust:
    Coming soon:
    DC headers 4-2-1
    Magnaflow high flow cat
    2.25inch pipe with magnaflow muffler.
    15inch Fat fives
    Falken tires 512 195/60/15
    Coming soon:
    DC front strut bar
    Tokico struts
    Nuespeed lowering springs
    Justins bars
    Front: EBC dimpled and sloted rotors with AEM pads
    SE-i rear disk conversion
    Rear: Powerstop rotors with AEM pads
    SE-i SS brake lines
    poly bushings in the front.
    Interior:
    Prelude 4ws steering wheel with leather wrap
    SE-i armrest
    SE-i cupholders
    coming soon:
    PP Guages with white face
    bezel
    newer shiftknob and boot
    OEM foglight switch
    Ice
    Pioneer tape deck 35wx4
    kicker 6.5 fronts
    almani 6*9 rears
    Exterior:
    Sylvania Silverstar lights
    JDM corners
    coming soon:
    rear mud flaps
    4g spoiler
    Clear bumper lights
    Teg Lip
    might take out all dents and paint it accord 07 color .
    edit i just found out its got tint now so i will update with pics tomorrow
    Overdosed A18A
    replaced dizzy,
    replaced plugs and wires,
    cleaned pistons and head,
    vacuum removal,
    mechanical secondary,
    newer coil,
    __________________________________________________ _________
    pics:
    whenhe frist got thhe accord
    now
  1. Accord of the Month Nominations - January 2009
    Last Post: 12-15-2008, 06:45 PM
  2. Accord of the Month Nominations - January 2008
    Last Post: 12-12-2007, 05:57 AM
  3. January 2007 Accord of the Month - thegreatdane
    Last Post: 02-02-2007, 10:53 PM
  4. Accord of the Month Voting - January 2007
    Last Post: 12-20-2006, 07:10 AM
  5. Accord of the Month nominations: January '06
    By NXRacer in forum Accord of the Month Archives
    Last Post: 12-13-2005, 08:50 PM
