OK, here is my objective: Replacing the brush inside the althernator, AND replacing Power steering belt and Alternator belt.
Now, I have taken the brush assembly out from the alternator, without taking alternator out. I will try to put everything back tomorrow.
When I put on the power steering belt:V-belt, there is no way I can fit the belt in to the groove. I did the following: tightly hang the belt to the Power steering pulley, then turn the engine. The belt slided in nicely.
What's the proper way for the multi-ribbed belt? Do I need to do the same way, or the belt is loose enough when the alternator is in the nearest position?
Thanks in advance.
