Results 1 to 5 of 5
Thread: air suction pipe?
    Jul 2006
    89' Lx
    Nashville, Tn
    air suction pipe?
    what is the pipe callled that runs from the exhaust manifold to the intake manifold? what is it's use, and what would happen if it was removed?
    stupid question, i know, but maybe someday it'll all add up.
    I've moved on to bigger and better things. 94 integra Gsr Sedan is my new ride. And theres big things coming for it.
    LXi User 87lxiaccord's Avatar
    1987 honda accord
    st.pete
    Re: air suction pipe?
    thats your egr tube and if it were to be removed you would have a big exhaust leak its for emissions
    <3 sohc
    Jul 2006
    89' Lx
    Nashville, Tn
    thx. all i needed to know lol
    you can delete it, but you will probably flunk visual inspection on emmissions testing. Just cut the pipe 2 inches from the manifold fitting and roll the end like a toothpaste tube, lots of hammering, welding optional.
    All it does is vent fresh air into the exhaust pipe in between cylinder firing. I believe the purpose of this is to make the catalytic more efficient (or to cheat on emmissions tests!) . It runs on a reed valve setup under a certain RPMs...
    10/Honda/Ridgeline
    NJ
    The egr also known as Exhaust gas recirculation system is supposed to dilute the fuel-air mixture to lower the NOx production under combustion.
  1. Straight Pipe ? test pipe VS high flow cat
    By Acid X in forum Performance
    Last Post: 07-10-2006, 11:41 AM
  2. true flex pipe VS. Socket joint pipe
    By Ace in forum Performance
    Last Post: 04-27-2005, 07:53 PM
  3. Air Suction Valve
    By TTSpider in forum 3geez Accords
    Last Post: 04-12-2005, 01:18 PM
  4. REALLY REALLY need EGR & Air Suction pipes !!
    By ZiggyxFresh in forum Trading Post
    Last Post: 02-22-2004, 10:39 AM
  5. He cut my #@!$%&* air suction tube....
    By 4DoorAccordDX in forum Carburetor Tech
    Last Post: 07-22-2003, 03:29 PM
