Results 1 to 5 of 5
Thread: good source for seat belt buckles for 89 LXi coupe?
    Nov 2006
    1989 Honda Accord LXi Coupe; 5 spd; completely stock
    Sacramento, CA
    hi, i just bought an '89 accord lxi coupe yesterday and neither of the front seat belt buckles work right. any ideas as to a good online source to get them at a reasonable price? fyi: the color is burgundy. thanks!
    Re: good source for seat belt buckles for 89 LXi coupe?
    i think there was a recall on them are the buttons broke
    here it is
    is free a good enough for ya just take it to honda
    Campaign Number: 95V103001 Date: 1995-May-24
    Component: Seat Belts: Front: Buckle Assembly
    Defect Summary: THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
    Consequence Summary: THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
    Corrective Summary: OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES. CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. CHECK THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUG ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, THEN PRESS THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS ANY SIGN OF BREAKAGE OR CRACKING, OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, PROMPTLY CONTACT YOUR AUTHORIZED HONDA/ACURA DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT THE FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
    yeah take it to your honda dealer...they should not charge you a dime...i took mine in..but they had to order the parts....just give em the vin number and its good to go
    Nov 2006
    Sacramento, CA
    Only one of the buckles has the cover, but that one does have the red button. I'll definitely check with a local dealer and see about a recall replacement. Wow, thanks for all the replies! Looks like this may be much easier than I expected
  1. Replies: 10
    Last Post: 04-21-2013, 08:31 PM
  2. Good Source For Rebuilt Engines?
    By marklj in forum 3geez Accords
    Last Post: 11-11-2008, 07:58 PM
  3. Good source for bumper covers?
    By RamThis in forum Interior & Exterior Care
    Last Post: 10-18-2006, 07:57 PM
  4. Good Power Source?
    By rollinhnda88 in forum Interior & Exterior Care
    Last Post: 01-13-2004, 12:05 PM
  5. Good source for a front fender?
    By accord250 in forum Interior & Exterior Care
    Last Post: 08-23-2003, 12:38 AM
