Results 1 to 18 of 18
Thread: pinch fork mod...
    LXi User Jasonf860's Avatar
    Jul 2006
    89 Accord lx, 94 BMW 325i
    pinch fork mod...
    The link no worky.... I'm hating having my car level. I wanna drop the front 1/4-1/2 inch to help with the understeer and this seems the best way to do it... Can someone help me out here?
    Re: pinch fork mod...
    Jul 2006
    Thanks Legend!
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Why do you think changing the pinch fork will reduce understeer?
    Mike
    Jul 2006
    By making the front lower than the back, it helps to reduce understeer by lowering the center of gravity in the front of the vehicle and also raising the rear center of gravity. basically making it easier for the rear to "come around" instead of it pushing.
    Vanilla Sky's Avatar
    1999 Penalty Box
    the way i'm looking at it, it would increase understeer, not reduce it.
    just get lx-i or aftermarket sway bars
    Jul 2006
    I already have LX-I sway bars. Honda designed both the lx and the LX-I to have equal understeer. the LX_I only corners flatter. The best way to get rid of the understeer as mentioned in other threads, is to use the factory lx front bar and add the LX-I rear. That stiffens up the rear enough to get rid of most of the understeer.
    Jul 2006
    Quote Originally Posted by Vanilla Sky
    How would you come across that? By lowering the center of gravity on your vehicle it provides better handling. If you only lower one side front or back, it will allow that part to get more grip. The higher rear end will tend to rotate easier since it has a higher center of gravity. Also, if you run lower air pressure in the rear (minimum for tire) and higher in the front (Maximum rating for tire) it helps reduce it as well. Example: http://rogerkrausracing.com/overundr.html
    Quote Originally Posted by Jasonf860
    ok get an aftermarket rear sway bar...i have the regular dx sway bar up front and a lx-i sway bar in the back...it handles very good...i changed out my shocks so yeah...wait till you get your tokicos...you will like em
    Jul 2006
    Yeah, i ran it with the lx in front and lx-i bar in the rear for a week then decided to try the lx-i bar up front. I really like the flatter cornering of the LX-i bar up front, but i agree, I will be looking into a bigger rear bar. Perhaps the vigor one if i can find one somewhere...
    yeah i heard about that....i did all the searching but yeah its just better to get the aftermarket one cuz it comes with poly bushings and its nice and thick...hehe
    Jul 2006
    Yeah, but lets put it this way... If you could get the Vigor rear bar for $20, or the ST rear bar for $134, what would you go with? I'm sure the ST bar offers better handling as it's slightly thicker, but $ for $ I'd say the Vigor bar is more bang for the buck.
    Jul 2006
    Just some good suspension reading....
    http://www.autozine.org/technical_sc...handling_4.htm
    do the vigor bars fit...if so wut year?
    Jul 2006
    Well, the Acura Vigor only sold for 3 years, 92-95. they did make some slight changes in the 95 year, but nothing crazy so I'd say they would all fit, but in the 95 most of the changes were suspension related to give it a softer ride so I'd err on the side that earlier is better. I am currently looking for a 92-93 rear bar from a Vigor, when I find one and fit it, I'll post and let everyone know once and for all if it works or not.
    Not answering your question but you can mess with the tire sizes to get the stagger you want just to try it out. If your feeling real frisky get a cheap set of rear tires tread wear about 300+ and about 1/2 to an inch taller and some real soft,200 tread wear or lower, smaller fronts and give me a ring a ling back. Watch it it the rain its hard to drive the rear on a fwd car .
    Jul 2006
    Well, I know that having the front lower does help. I had the front set about 3/4 inch lower when I had the coilovers. It didn't get rid of it completely, but it did help some. I'd say I am close to neutral now with my set up, so if I drop the front a half inch or so, it should be right where I want it.
  1. who else has done pinch fork mod?
    By mykwikcoupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-25-2010, 02:44 PM
  2. [Suspension, Wheels, Tires & Brakes] Drop the front 1/2" doing the pinch fork mod
    By Jims 86LXI HB in forum How To
    Last Post: 08-19-2008, 05:53 PM
  3. Replies: 20
    Last Post: 03-23-2007, 11:28 AM
  4. Damper fork pinch bolt
    By Acid X in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-29-2005, 01:41 PM
  5. Siezed pinch fork to lower arm bolts...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-24-2005, 12:49 PM
