Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Black Box removal. and manual choke control.
    Re: Black Box removal. and manual choke control.
    did you plug up everything? hear any whistles or hear it sucking for heaps of air?? or did you remove the idle diaphram thingy??
    spray some carb cleaner..and if the idle goes up or down you got a leak
    shouldnt have a vacuum leak without any hoses
    only hoses you should have left is the dizzy advance hoses
    only hose i have left (other than the main ones) is the dizzy advance hose #2
    well i would leave the main ones...anyways...i want to see pics
    Nov 2006
    Ok ill see whats up when i get home tonight. i do have some lines left on a black box that is right behind my valve cover.
    Also do i need my carb electrical plug plugged in?
    Ill get pics asap. girlfriend stole the camera for the week.
    90 Acura Integra JDM B18B swap soon to be on 6lbs.
    89 Honda Accord LX 4dr. Daily.
    Nov 2006
    Talking Re: Black Box removal. and manual choke control.
    OK guys do i need this stuff. and do you see anything wrong?
    Heres a few of the choke and shady black box removal.
    Nov 2006
    Wheres the quick resposes this week? ;p
  8. #33
    can i have more pics of that choke setup?? other than that it looks good to me, you dont have to get rid of that purple box. i dunno about that choke puller, but if you take it off, there should be a hole, you should plug that. i dunno, not sure about that. but looks good
  9. #34
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    You can remove the "Choke Opener" but you'll need to plug the hole (JB WELD) on the carb when the Choke opener is removed or it'll cause a vacuum leak.
    The hole will be on the front next to the threaded hole that the lower choke opener screw went into.
  10. #35
    Nov 2006
    Ok well i cant figure it out. The thing wont advance, it will kind of idle but it wont advance like its not getting spark. although i know it is. How exactly is my distributor supposed to be hooked up. like the vacuum on it. i got it "T"d going to my carb and mani.
  11. #36
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Nevermind....
  1. Manual Choke
    By SILENT in forum Carburetor Tech
    Last Post: 11-06-2011, 12:52 PM
  2. manual choke
    By mephi in forum Carburetor Tech
    Last Post: 04-10-2009, 11:48 PM
  3. Choke removal...?
    By Tailfin in forum Carburetor Tech
    Last Post: 10-23-2006, 01:18 AM
  4. Replies: 3
    Last Post: 11-28-2004, 07:34 PM
  5. weber manual choke or electric choke?
    By myaccord7 in forum Performance
    Last Post: 11-07-2002, 04:27 PM
