Well as i have now found out that the ignitor in the OBD1 distributors doesn't like to be used with a MSD box. My car is not currently running b/c of it.
I did some research on Honda-tech and PGMfi and found out there is a way around running a ignitor if you have a MSD. You have to build a trigger adapter to replace the ignitor and to wire the MSD to. Here is the diagram.
I'm going to order all of the parts from digikey, the only problem is that they don't currently have the ztx857 in stock but they have some on order and their order is late. According to the PGMFI wiki you can use a different part to replace the ztx857, but i don't know enough about transistors to find the correct replacement.
Any wayI thought i would share this if any one else need the info in the future. If you can help me find a replacement it would be much appeciated.
