Results 1 to 7 of 7
Thread: 89 Acccord LXI Check Engine Lite
    '89' Honda Accord Lxi EFI
    Upstate NY
    The check engine lite comes on in My 89 lxi accord, EFI, however, there is no loss of power but there is this pop corn sound that seems to be coming from the throttle body area and when I'm coasting down hill the the RPMS goes up and down. The strange thing is that when the car is stationary and I step on the gas the engine sounds normal.Also my gas milage is a little lower
    Got any suggestions?
    thanks, Jim
    Re: 89 Acccord LXI Check Engine Lite
    check under the seat...at the computer...pull up the flap and it still tell you a code then check it.
    shepherd79's Avatar
    Falling Waters, WV USA
    follow this link for your answer
    https://www.3geez.com/forum/showthread.php?t=26342
    Upstate NY
    I'm getting code 14 Iac valve?
    Should it be replaced?
    shepherd79's Avatar
    check the wires around the connector first.
    If they look Good, replace the valve.
    LX User azazel_18_2's Avatar
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    I have a brand new IAC still in the Honda Box!! It will run ya $105 shipped but I may trade if you some something I like. PM Me!
    Nov 2006
    In the 4th Gens, IAC would build up gunk overtime and cleaning them definately helped the idle. I would first remove it and shoot some carb cleaner down in and see if that helps. But like Shepherd says, check the wire connector first (it right there by the TB and I believe has a 2-wire connector going to it).
  1. Gas lite
    By skinner17 in forum 3geez Accords
    Last Post: 10-26-2009, 06:00 PM
  2. check engine????
    By levon2008 in forum 3geez Accords
    Last Post: 04-29-2008, 10:01 PM
  3. check engine when i go over 85??!!!??!!!!!
    By crazykamper in forum 3geez Accords
    Last Post: 12-29-2005, 05:52 PM
  4. Vid My Turboed 86 Honda Acccord
    By adams86lxi in forum Classic Honda Pics & Videos
    Last Post: 09-20-2005, 05:15 AM
  5. lite wheels?
    By HondaBoy in forum Classic Honda Community Chat
    Last Post: 03-03-2003, 09:56 PM
