So i just finished my water pump replacement. When my brother and I bleed the system, for a little bit there was orange colored coolant squirting out of the bleeding screw. After about 15 mins of the engine running, it turned green and there was so sign of orange coolant. I did flush the system out with water, including the block. If there is no more orange coolant coming out, should i be worried? The coolant in the radiator and the tank are green.
