Dude if you can't figure out how to swap a carb, or fix the current one, what makes you think you'll be able to tackle an entire engine swap from a different car? You know that if you try a Weber swap, you'll be looking at at least $300.
First off the adapter plate will run you about $100.
A USED Weber will be about $100.
If you buy a used Weber for $100, a rebuild may be in order. Who knows how that will run.
A jet kit for the Weber will NOT be cheap.
Hours and hours of tuning...
Your only hope at this point is to rebuild the carb you have, IF that is your problem. I'd hate to find out why you think you need to swap to a Weber.
You're not trying to fix your problem, just trying to get around it. Your solutions are getting worse and worse. First it's carb swap, then manifold swap, then engine swap. Since none of those can be done in a day with $20, you might as well go all out and just get another car or something... I mean really dude. It doesn't sound like you wanna actually work on the car.
