Hey i would like to know what some of you other 2nd gen guys speed runs are like. I've only got my car to push 170KPH on the highway. and i would like to compare it to other peoples runs
my friend had a 85 se-i and he got it up to 115 mph. very solid car for its age.
umm 170KPH is about 107MPH. and thats good. cause my car has a busted carb. so with the weber i bet i could beat that seI
lol...@ old cars going fast
wuts soo funny? look at the ferraries.....even a 60s car and put a spanking on our a20sOriginally Posted by Cheeseburger
those cars are ment to go fast our cars are not![]()
thats impressive for a 2nd gen
my 86 hatch has hit and sustained 120mph several times
well for stock i hit 120 when i first got it....the part that sucked was that you can see the gas needle go down...lol
well being that my engine has 88HP stock. well with the carb I have in it now maybe 45HP it can do 107. with a new weber in there I might be able to pull 125 or 130.
Originally Posted by Holy^ghost
yup also your gas mileage will go down....lol
im expecting that
160 km/h so far. didnt have much room to axelerate more.
My Build Thread
In my 85 1.8 Auto, in the late '90's when it was last on the road it manged 110-115 mph IIRC.
My 84 does about 105-107mph on a long flat stretch in 5th gear. That was all stock. Does about the same with the Weber on stock jetting.
I can wind it up to 110 in 4th gear, but I don't like cruising at 4500rpm. It will cruise at 105 just fine in 5th without the motor screaming.
I found out the hard way that the weber don't fit on my A16A1 engine. so i had to order one from the dealer who has to import one from japan. plus my accelerator diaphragm is messed so i needed to get one as well. I hate having a rare engine.
put in an a20 then run a webber....you can find them cheap at the junkyard.Originally Posted by Holy^ghost
Yeah I hate to say it, but you've probably got the rarest Accord engine. So you wound up ordering the Weber and trying it out?
If you've still got the Weber, just fab up an adapter plate out of paper and go to your local shop. They'd probably make you one for less than $50. Just trace out a square plate that you can bolt to the manifold. Then place the Weber on the square you made and trace out the holes in the carb and an elongated hole around the throttle bodies and you're set. Hell, I'll come up there and help you make one... I guess assuming you've still got the Weber. If you sent it back already, the factory one will work just fine.
He is in C a n d a d a d a , do they have junkyards?Originally Posted by MessyHonda
That does sound rare, and I wonder why the A20 weber adadtpers wont work, why would they do that to us.
My 86 did 100 before I did mods, going downhill on interstate, I Have not tryed it since.
Our cars ARE made to go fast Cheeseburger, why would they put 130 on teh speedometer, why why why
Well back when I had my 86 DX I got it up to about 120MPH. Kinda scary though in that car.. As for my current car I've reached 180 KM/h. I know it's kinda slow, but my speedo only goes to 180. It can go faster though. My RPM's were only at about 4500 or 5k.
84 Lx stock everything 110 MPH
03 EX Accord, all stock, 126 MPH ;-D
- The Rockcord (AKA CJ)
84 Light blue LX sedan 265000
BT mafia All the way
(or Prelude power)
Yes i have the rarest accord engine ever. BTW i sent back that weber and ordered a 3 barrel carb from the dealer. the only after market carb for the engine I have. ohh and does the a20 have the same mounts as the A16A1 and yes canada has junk yards. could I put a fuel injected A20A1 into my car or would i have to change the tank aswell.
A20A1 is carbed A20A3/4 are FI
I don't know if your mounts will work or not, but I would assume your mounts would bolt right up to the A20 engine. The ES2 mounts bolt up to the A20 engine.
You don't need a new tank, what you need is to run a return fuel line, replace all your old lines with high pressure fuel injected lines, and get an 85 SE-i fuel pump or any other fuel-injection pump.
The whole A20 process has been done by PhydeauX. He's the man. He did the Dual-Weber route though. So you'll have to combine the A20 swap info, with some of the carb to fuel injection how-tos here. But as far as swaps go, it should be straightforward. I believe your transmission will bolt right up to an A20 as well, so no messing with axles and splines if you don't want to.
If the A16 mounts won't work for some reason, I'm sure we could get you the ES2 mounts, and those would work in your car just fine.
Everything I know about this stuff though is just from reading on this site and a tiny bit of external research. So take anything I say lightly, and double check me. PhydeauX knows for sure, as he's actually done the A20 swap.
that will be of great help when i gain accsess to my schools autoshop next semester. and ill send pics of my enigne. but i dont know how much different looking it is from the 1.8 I can't find pics of the ES2 engine. can one fo you guys give me a link to a website or take pics of your engine so i can compare the differences
VERY WELL SAIDOriginally Posted by 2ndGenGuy
and btw holy^ghost I was kidding with messyhonda about the canadian junk yards.![]()
my car im sure will go faster than 100, I really have not tryed except for on the commute to work and there is too much construction going on, and yes is it kinda scary in a 20 year old car![]()
