Results 1 to 5 of 5
Thread: A/C Belt
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    A/C Belt
    How the *BLEEP* do i get this thing off?
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    Jul 2002
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    I took just took the compressor out. If you're unhooking the A/C to possibly free up some power, might as well get rid of the compressor to lighten your car.
    Mike Clark
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    if you just want to remove the belt loosen the tensioning nut (long 12 mm nut that points towards the engine on the left side of the compressor). Also loosen the mount bolts enough to let the compressor move after loosening the tensioner bolt. Tilt the compressor back and off the belt goes. You'll need to remove the PS belt to get the A/C belt off whole.
    Mike
    If you dont want to use anymore your A/C the easiest way is to cut the belt
    But guys are you really thinking you gone gain some HP????
    Because i thought that if the a/c is not on you dont use much power????
    10/Honda/Ridgeline
    NJ
    its not about gaining hp which is true cause u do take up power from the main crank when the ac on, but the damn compressor weighs atleast 25 to 30lbs. if its not working, take that shit off. when u do, or before u do it make sure ur system is fully discharged. take the compressor off and take of all the shit that goes with it. take off the dryer and the condensor on the front of the radiator. just make sure u plug all the holes in the system to prevent dust from getting in.
  1. PS Belt
    By Ludi Mali in forum 3geez Accords
    Last Post: 11-17-2005, 08:20 AM
  2. A/C Belt!?!?!?!?
    By InfinityAudioLXi in forum 3geez Accords
    Last Post: 11-15-2003, 03:24 PM
  3. AC Belt?
    By erics86dx in forum Performance
    Last Post: 09-19-2003, 01:16 PM
  4. T-Belt
    By 86AccordLxi in forum 3geez Accords
    Last Post: 08-12-2003, 07:06 AM
  5. AC Belt
    By 1989se-i in forum Performance
    Last Post: 01-14-2003, 03:07 PM
