Noticed today that my car leaks about tablespoon of oil when running for 10 minutes, but if I park somewhere else, there is no oil, so its leaking when running, but not when parked and turned off. Where could this leak be?
could be anything oil is under pressure so look for rear man seal oil filter seal dizzy seal and valve cover and anything else that could leak oil
yeah check the engine see if its coming from the rear...front or side of the engine.
coming from the front i think, but will check more tomorrow
it was the same problem to me. it was leaking from the seal on the crankshaft (on the gearbox side). you should take off the gearbox to change it
i have the same problem with the lx
