Just ran into some problems and found out this will not work. I have a couple more tricks up my sleeve and I will let you know how this all works out. One more time this dosent work if you read through the thread you will figure out the problem. Click this link for a fix to the problem.
- 1987-90 Legend Coupe or 1989-1990 sedan rear calipers.
- 1987-90 Legend Coupe or 1989-1990 sedan rear brake pads
- 2002 - 2003 Civic SI Hatchback rear 10.2" rotors (THEY MUST BE 4X100)
- 1988-1989 Accord Se-i rear hubs and spindle
all you have to do is bolt the disks on then bolt the calipers on. No modification is required to the disk or calipers. You will have to bend the dust shield a slight bit to allow for the larger caliper. Here are the mock up pics without pads, but I will get some better shots once I get the hubs installed on the car with pads in them.
Old rotor on the left new one on the right.
