Well over here we have an annual goverment test called the MOT which is what my 2g has just had done. It failed on 1 washer jet inoperative (forgot to fix!), 2 tyres had bulges & emmision readings too high.
First of, they flooded the engine when they started the car (not easy to do on my car btw) & they put it through the emmisions test firing on 2 or 3 cylinders - hardly my fault. They said new spark plugs were required but they were renewed 700 miles ago. I went up to the garage & got it firing on all 4 cylinders within 3 minutes.
They put it through the emmisions again & it failed, though not so badly.
The MOT man tells me he spent some time adjusting the carb settings & it passed the test.
I've just collected the car just before the garage shut for the night & its running like crap! I'm deeply pissed off ! The idle is erratic, running mainly between 600 rpm & 1000 rpm & almost cutting out at times, even with throttle (when driving) its running unevenly.
Beforehand the engine was running very well (except for an occasional slight misfire at idle? Suspect HT leads), fuel economy was good & idle speed constant at about 800 rpm.
I will have to take the car back but I'm less than confident that they'll have the car running correctly so I'm thinking maybe I'd rather fix it myself?
What could they have done to it to make it run so badly, why did it fail the lenient emmisions test when it was running so well with good economy, will adjustment of the carb to get the car running correctly result in high emmisions again?
