*****1/25/09This car is for sale again. This time for sure or will be sold on craigslist locally. [email protected]
https://www.3geez.com/forum/showthread.php?t=53419
I know some of you guys have been waiting for this for a while and i personally have been too. So we finally dynoed the rebuilt motor and did a little cam test as well. We dynoed our race cam first and then our Mild 256/270 cam. Run#9 is the Race cam and #13 is the 256/270. The race cam topped out higher and torque didn't die off as fast, but the mild cam killed it in the bottom end. Torque was a good 10lbs/ft higher all over with the mild cam. Those of you who were fortunate to get ur hands on our 256/270 cam got an excellent cam which passes CA smog as well!
A20a3
Standard Ph4 1mm overbore pistons
Stock Rods ARP rod bolts
83.7mmx91mm
Stock valves/springs/retainers
Welded Combustion chambers, P&P head (around 10.5:1 CR)
P&P B16a intake manifold
63mm overbored LS TB
8lbs custom aluminum flywheel
Custom aluminum underdrive crank pulley
256/270 cam or race 289 cam.
Golden Eagle Cam Gear
Obd 1 conversion
Chipped P75 Ecu
290cc Prelude OBD2 injectors
B&M fuel pressure regulator
MSD 7AL2, and blaster coil
DC sports Header
Straight pipe with 2.25 exhaust
The race cam
The 256/270 cam
The master mechanic at work
And there are some videos on youtube here:
http://www.youtube.com/profile?user=MrMike8300
i'll post some more pics of the engine while it was being rebuilt a little later since i think they got deleted from an older thread. There some here and yes this car is going to be for sale.
