Results 1 to 16 of 16
Thread: very little heat in the car during winter...
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    i know this isnt about my accord, but the corolla im driving right now has very little heat coming out of it. i remember when i first started driving it, it was a sauna in there when i turned it up, now its like its dying or something. im guessing its not the water pump going as the engine itself isnt overheating in any way. possible that the heater core might be clogged?
    Re: very little heat in the car during winter...
    check your coolent level my smart friend had 100% coolent and it did not heat up at all...then he added water and it worked just fine.
    race12001's Avatar
    Sanford NC
    yea its possible the heater core is cloged pull off one of your radiator hoses and see if your fluid is slimey if it is you need to flush it
    Dec. 05-Dec. 06
    Jun 2005
    Edmonton AB
    its not empty or anything, but ill try draining and refilling the rad to see if it helps
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    If you heater core isn't clogged, then the thermostat is stuck in the open position.
    Jun 2005
    Edmonton AB
    im not sure if that might be it as the car heats up perfectly, even while im driving it. i always thought that if it was stuck open, it wont heat up the car at all?
    we had the same prob in the 89 and it ended up being a clip on the back of the heater controls
    carotman's Avatar
    Montreal South Shore
    It could be the heater core valve that doesn't function anymore. That valve is in the engine bay and it's driven by a cable. Have someone move the temp slider in the car and check if the valve moves freely.
    race12001's Avatar
    Sanford NC
    it could be a hundred diffrent things you just need to start some where and work your way down the list though what it could be
    Dec. 05-Dec. 06
    Jun 2005
    Edmonton AB
    im leaning towards a clogged up heater core cause when its not blowing really hot, i can momentarily the heater off, and when i turn it up again, its blowing hot again. any suggestions on how to unclog it without having to replace it?
    race12001's Avatar
    Sanford NC
    take your heater hoseses off and put a blow nozzel on one end and stand out of the way and push it out
    Dec. 05-Dec. 06
    If it's not either of those check your belt, if it's not that then your water pump is shot.
    Jun 2005
    Edmonton AB
    if the pump was shot, wouldnt the car overheat?
    Jun 2005
    Edmonton AB
    Quote Originally Posted by race12001
    can i use a hose and blow it with water?
    race12001's Avatar
    Sanford NC
    not if its cold out side cause i drive my car with a busted radiator and it only over heats if i sit still but if i keep the air curculating around the engine bay it dont
    Dec. 05-Dec. 06
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Generally on most cars, there is two lines that go through the firewall to the heater core. Inlet & outlet side. You can use a blow gun hooked up to a compressor to try to blow the heater core out. Just unhook both sides, to be safe. Look for a valve on that Corolla like these Accords have when moving the heater controls near the firewall.
  1. Replies: 19
    Last Post: 05-05-2012, 02:35 PM
  2. No heat
    By dani_ocean in forum 1geez Accords
    Last Post: 10-17-2009, 06:01 PM
  3. Heat
    By Whistler225 in forum 3geez Accords
    Last Post: 04-08-2006, 03:24 PM
  4. retaining carb heat function for the winter with the scoop
    By lostforawhile in forum Carburetor Tech
    Last Post: 11-12-2005, 04:58 PM
  5. Which oil is best for winter?!
    By pimp86LX in forum Classic Honda Community Chat
    Last Post: 12-04-2002, 03:45 PM
