but you're still stuck with the wrong b20. first off, it's the b20A that bolts in and that's a b20B. secondly, the b20A that does bolt in was never available in n. america. b20a5 and b20a7 will not bolt in. and neither will the b20a from the 3g preludes, which have engine serial # starting with 5xx,xxx. the one that bolts in has serial # starting with 1xx,xxx. also, the one that bolts in has the oil filler cap on the tranny side of the valve cover, prelude b20a has oil filler cap on accessory side. now if you do want to put in the b20b, it's the same as putting in a b16, b17, or b18. the mount points are all the same between that family of engines.
