Yeah, it runs unreal when it's cold for about 5 minutes, but I don't like running it hard until it's hot. When it's warm it bogs real hard, idles way rich, misses under part throttle and loads up. Sometimes WOT cleans it up and it pulls hard, but usually it surges, stumbles and bogs.
Don't know if its ignition timing, cam timing or fuel at this point, or one problem influencing the ECU and causing numerous other resultant problems.
It has a new Bosch O2 sensor, and it seems to idle better with my sucky buddy sucking hard on the line to the MAP. Seems more vacuum makes the computer lean it out. So maybe low vacuum caused by wrong cam timing? Or too much fuel? We had to open the idle adjust screw quite a bit to get it to idle at all, so maybe excess fuel made us open up the intake to get it to idle which drops vacuum and confuses the MAP and ECU which makes it run worse?
Also when it's hot, sometimes I open the throttle to pull away from a light or stop sign and it stumbles and backfires (intake).
So something isn't right, and I'm sure it's one factor causing most of the problems.
(yay first post on foundation membership, gonna go check out the other features now!!)
