Page 7 of 7 FirstFirst ... 34567
Results 151 to 156 of 156
Thread: Engine Swaps
  1. #151
    DX User SA6's Avatar
    Mar 2011
    1985|Honda|Accord LX
    Indonesia
    Re: Engine Swaps
    B20A will fit too, but you gotta figure out what axles to use. You can check my swap thread, or Ichiban's, though his setup is a bit different. A20 is going to be the most direct, as your A16 transmission will bolt right up. Also, does your car really have an A16A in it? You sure it's not an ES or EZ or something?
    im not sure
    it maybe ez or a16. what is different between them? later i will check it. sorry im noob hahaha..
    thanks for your answer
  2. #152
    Mar 2011
    Indonesia
    Red face Re: Engine Swaps
    i have checked it. it is ez2 hahaha..
    if i swap it with b20, i only modify the axle, right?
    2geez, 3geez, and 2nd gen prelude have same motor mount, right? any another type of honda that has same motor mount with 2geez?
    will b18 fit too?
    thanks
  3. #153
    LX User Christofur's Avatar
    Jul 2010
    85 SE-i / 1997 VW Golf
    Auburn, Washington
    Re: Engine Swaps
    heres my question is an a20 intake mani the same as a es3 intake mani?
  4. #154
    Re: Engine Swaps
    Quote Originally Posted by Christofur View Post
    Not even close
  5. #155
    Jul 2010
    Auburn, Washington
    Re: Engine Swaps
    Not even close
  6. #156
    Ichiban's Avatar
    North of You.
    Re: Engine Swaps
    Quote Originally Posted by SA6 View Post
    will b18 fit too?
    thanks
    Not really. The prelude rear crossmember is at a different height than the 3g accord one, so the motor mount brackets are different. The Prelude ET2 front mount is also longer than the A20/B20 front mount, this is the one I had to use in my car.
    B18b,c,etc engine is hung from the ends, not front and back like the A20/B20A are. Totally different.
    ICHIBAN!
    "Now, even more better!"
  1. Engine swaps
    By locrion in forum JDM B18A / B20A Swap Tech
    Last Post: 09-13-2008, 08:51 AM
  2. Engine Swaps
    By BeatThisLXI in forum General Engine Swaps
    Last Post: 09-22-2006, 12:28 PM
  3. New to Accords, need to know about some engine swaps...
    By panaphobic in forum General Engine Swaps
    Last Post: 04-06-2006, 03:06 PM
  4. what engine swaps can i do
    By surenoracer13 in forum General Engine Swaps
    Last Post: 01-24-2003, 02:44 AM
  5. engine swaps
    By redwhiteaccord01 in forum General Engine Swaps
    Last Post: 08-07-2002, 02:42 PM
