Page 22 of 56 FirstFirst ... 1218192021222324252632 ... LastLast
Results 526 to 550 of 1391
Thread: Pico's 89 LX-i Build
  1. #526
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Re: Started Pulling out my Engine and Transmission today (56k I do not recommend)
    Yeah they did send one with the cam, I going to try this weekend to install it and play with the cam gear
    Can you scan it? or list the specs?
  2. #527
    Here's the spec sheet, Since I really dont know too much about the technical things about engines, can you break it down for me
  3. #528
    sweet to bad it looks like they rubbed crap all over it then shipped it lol they should have had it clean
  4. #529
    nice pico
  5. #530
    i had my valve leash set to stock even with my 280 cam.
    too legit to quit !!
    that is one dandy bumpstick, great thread..
  7. #532
    nice
  8. #533
    I just picked this up tonight from buish, Brand new DC Header. These are the pictures that buish took, I havent took any new pic's yet.
  9. #534
    LXi User Catalyst's Avatar
    Dec 2006
    87 Accord Lxi Hatchback
    Murphys, CA
    Thats a beautiful thing pico.
  10. #535
    sweet looks like no carb # on yours either.. are they carb legal i thought they were
  11. #536
    i wish my car was nice and shiney like yours!
  12. #537
    1991 Civic STD
    Arbutus, MD, Baby
    DC Header! Nice.
    Daily Drivers Done Right
  13. #538
    Just finished installing my delta cam.
    I still have to adjust the valves and start it up and adjust the timing
    It has the carb tag
  14. #539
    Cant wait for that video
  15. #540
    sweet...hope it starts up fine...mine sounded like a chevy
    I finally got around tonight to finish the cam installation, broke it in at 2200 rpm for 20min's she's running like crap right now, idle fluctuates between 850-1000 rpm.
    I need help fast.....
    maybe i'm a tooth off on the timing belt?
    Did I install the cam wrong?
    Valve lash is exhaust 8 intake 6
    HELP.............
  17. #542
    Even though i have never done this, but i would check to see if the T-belt is on correctly and isn't off by a few teeth. Did you try adjusting the timing in any way?
  18. #543
    Dec 2003
    Millington, TN
    Check the simple stuff first dizzy, timing belt, throttle cable
    Phil
  19. #544
    Quote Originally Posted by nswst8 View Post
    I checked and triple checked the belt, I dont know it may be off a tooth. I tried to adjust the dizzy and it made only a little bit of difference.
    going to try playing with it more this weekend
  20. #545
    Maybe you need to mess with the timing since it is a different cam.
    I also need to figure out why my car wouldn't drop the idle this morning until 10 mins of warming up
  21. #546
    Mar 2007
    89\90 accord lx 4dr
    internets 2008
    That looks like its the embodyment of the fusion between the sex, epicness, and is made of 100% pure win.
    You lucky mo$*#^er%#cking%#$@#$#.
    I want i want i want.
    EDIT: i also want pics when its in!
  22. #547
    Dec 2003
    Millington, TN
    What about the adjustable cam gear is this set to zero?
    Phil
  23. #548
    LXi User RamThis's Avatar
    N. Richland Hills, Tx
    Wow Pico, I never even saw this thread all year!!! I went through it all last night and Im simply amazed by what you've done!!! I wish that so many of you 3G guys didnt live way out in Cali, I'd love to see your cars. It'd give me some inspiration to work on mine again. I keep getting distracted by other projects and pulled away from it. Oh well, maybe someday.
    As for your idle problem, I have no clue. Have you hooked up a timing light and checked to see where you are at with your timing? That would tell you really quick if it's a timing issue or if you need to move on to something else. I wonder, did the engine surge before you did the cam break-in? Or only after you let it run at 2200 for 20 minutes? If it only started this after it ran maybe you had a coincidental failure of a sensor somewhere, or a vacuum leak? Have you checked your manifold vacuum yet?
    View my Image Gallery
    1989 Honda Accord LX
    2006 Toyota 4Runner SR5
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
  24. #549
    it is set to zero, I'm wondering that if the timing was 180 degrees off would the car still start and run like it is running right now ?
    Quote Originally Posted by RamThis View Post
    Thanks RamThis it's not as major a job as your doing, but it's all I have the time to do on her.
    as far as the idle it started from the after I first started the car with the new cam.
    Hopefully it something really simple and that I'll be able to get her fixed ASAP.
  25. #550
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    It could be 180 out, but I don't think it would run. It might be that your ECM needs a re-learn with this new cam. Unplug your battery terminals & touch them together for about 30 seconds. (hard re-learn)
    The car might need about 10 runs for the ECM to relearn parameters. Also, have you checked for any codes?
  1. Pico's Daily Hatch
    By Pico in forum Project Central
    Last Post: 07-24-2012, 07:09 AM
  2. Pico's 1988 LX-i Hatch Before and After
    By Pico in forum Classic Honda Pics & Videos
    Last Post: 06-05-2011, 05:15 AM
  3. Pico's 88 Lx-I Daily Driver
    Last Post: 11-01-2010, 03:40 AM
  4. Yet Another White 3G in Pico's Garage
    Last Post: 04-05-2009, 12:21 PM
  5. March Accord of the Month - Pico
    Last Post: 03-19-2009, 07:02 PM
