Okay so according to the Factory service manual, the rod bearing clearances for new bearings in my EK1 are:
0.020-0.038mm or
0.0008-0.0015in
With a service limit of 0.07mm or 0.0028in.
So I checked with plastigague and I got somewhere between 0.002 and 0.003.
The wierd thing is that this is the LAST bearing in the whole engine to be torqued down. All the other bearings were well within spec. The crank and rod bearings. I'm just wondering if this is normal to happen just because all the other bearings are tightened down, or if I actually happened to get one screwed up crankshaft rod journal, and it happened to be my last one.
If it's actually screwed up, should I just go buy a new bearing that is for the slightly smaller crank, and plastigauge it to make sure the clearance is tighter? Or am I okay?
Here is the page in the FSM so you can see what I'm referring to.
