Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: Overflow tank bubbles and makes a weird noise.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Overflow tank bubbles and makes a weird noise.
    For those not familar with Mr. Magoo.
    Well, a bad water pump can cause the water to boil too, along with clogged radiator, thermostat, head gasket. Without a pressure tester to hook up to the radiator cap opening, take it to a shop without all the wild guesses.
    Banned ahmad89's Avatar
    Dec 2006
    yea its at a shop right now and my dad will change the radiator and pumps
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    Re: Overflow tank bubbles and makes a weird noise.( headgasket)
    ahhhh..better do a cooling system leakdown test first..my swag is the headgasket is going shortly after that the real fun begins
    Quote Originally Posted by njpeter
    No Doubt
    I think he needs to get his flux capacitor in calibration before any accurate prognosis can be determined
    Quote Originally Posted by roodoo2
    No Doubt
    i got some accel wires in mine look at it
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Well, the flux capacitor may produce an invisible magnectic feild of protons & neutrons, in some cases causing free electrons in orbit that are not locked to protons. The conventional theory states that current flows from positve to negative, but calculations of the prognosis can be electron theory, which flows from negative to positive. Flux capacitors are highly sophisticated equiptment in finding leaks in the cooling system, depending on the induction, unlimited current flow & how much they absorb unwanted current flow. Hopefully they are integrated circuits with a powerfull enough amplifier to transpond accurate measurements.
    Dec 2006
    wow this thread has gone from help to back to the future lol. I dont need help with this anymore it stopped after i took it to the shop.
  8. #33
    i used some Dynomat....keeps it nice and covered and i bust it out when a civic wants to race.
    Ouch MH, well good thing you have your bases covered, you will be prepared when a member buys that 83 Civic on Ebay , you know the one, I have not been able to sleep at night scheming how to get it.
    ddude2uc, excellant 'laymans terms' on explaining the diagnostic equipment, easy to understand. I actually had a use for that a few years ago when I installed the wrong water pump on a Ford (Flip Over Read Directions) , serpentine impellers went opposite directions creating a + current charge on the coolant, took out all sensors and ECU, blew 4 different heater cores,made the inside door hardware punch thru the metal in the doors, steering column caught on fire, and made the clear coat peel off.
  1. new coolant overflow tank i put it here to give others ideas.
    By lostforawhile in forum Restoration & Custom Fabrication
    Last Post: 05-09-2013, 09:58 PM
  2. my in car fan makes noise when i use it....
    By Vindicted_Reprise in forum 2geez Accords
    Last Post: 01-02-2009, 12:16 AM
  3. engine makes crackling noise
    By fcov in forum Carburetor Tech
    Last Post: 07-11-2006, 05:47 AM
  4. Reverse gear makes click noise when Reversing
    By 1988_5spd_lxi in forum 3geez Accords
    Last Post: 05-20-2004, 04:31 AM
  5. Why It Makes That Noise
    By 88ebrake in forum EFI Tech
    Last Post: 05-06-2004, 02:49 PM
