I have searched and still have not found my answer. I have been worried that my alternator belt is to tight. After replacing the water pump, i replaced all the belts and tensioned them correctly. After a few miles, my alternator belt would squeal in the morning for about 3 seconds. So i tightened the belt a little, and it stopped. After checking the tension, if i push on the belt between the water pump puller and the alt. pulley, it flexes a little. I do not need to apply a lot of force to get it to flex. This sound normal or is it to tight? It does not flex a lot tho...
