ghost103
First off I want to apologize for sounding like the n00b. With that said I have a very strange problem. I own a 89 lx-i and the car runs great, but when its cold and sits overnight its almost almost impossible to start in the morning... Its takes about 20 min to start! But once its started or if its over 50 degrees it starts right up on the first crank. I Put a jumper on the blue wire under the dash and it threw a code 12. which is a bad egr valve.. Now would that cause it to not start? I have A new cap,plugs,wires,coil,fuel filter,pump and replaced the main relay (which I know is the most obvious problem). Has anyone experienced this problem? Thanks
Sorry EGR VALVE, OH and I have spark and Pressure at the rail
