Results 1 to 25 of 30
Thread: teg spindle set-up
    10 sec 87 honda accord Lx-i
    Hamden,Ct
    teg spindle set-up
    I needed a bigger hub bearing so I can get a set of Driveshaft shop axles to handel the power. So I took a 91 Integra control arm and had it fit on my car and it worked. So if any one needed bigger brakes or anything else should try it. The only difference is that where the steering rack mounts to the knuckle is about 3/4 of a inch in towards the wheel. I hope this will help someone.
    Re: teg spindle set-up
    nice find...so it was bolt in almost?/
    pics would help
    hey got any pictures? that'd be nice to see what you've done.
    Hamden,Ct
    It will bolt up with no problem but I sent all my suspension parts to get powder coated. I will post pictures when I put it back together
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    so 91 integra spindles fit our cars, or just any integra from that generation?
    are the brakes bigger on the integra?
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    good stuff johnny... thanks for the info.
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    You used the integra lower control arm and the integra spindle? Or only the spindle?
    Link to my 3geez garage
    i knew 2gen teg had simular front suspention.
    Hamden,Ct
    It has alittle bigger brakes and I used the whole arm, spindle and all
    Vanilla Sky's Avatar
    1999 Penalty Box
    does the swap change the suspension geometry?
    Hamden,Ct
    It changes it alittle because the teg arm is 3/4'' longer , all mine suspension parts are adjustable.
    1999 Penalty Box
    can the accord arm be used, or must the teg arm be swapped in?
    Hamden,Ct
    I don't understand the ?
    Jan 2003
    Denmark/Europe
    I think he's asking if you can use only the teg spindle and use the accord upper and lower control arms.
    Hamden,Ct
    I am still using the accord upper with the whole teg set-up spindle and all. Our axle spinles are the same as a teg
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Quote Originally Posted by newaccorddriver
    they're the same size and use the exact same caliper as the 88-89 lxi-sei
    Hamden,Ct
    The caplier is different than the 87's but is 88 89 caplier bigger I am not sure.
    1999 Penalty Box
    i'm going to have to pull a set and take some measurements. the teg spindles may move the hub up or down a bit, giving the suspension a lift or a drop, depending.
    yeah the 86-87 came with like 9 inch rotors and the 88-89 fuel injected came with 10.2 inch rotors
    guaynabo89's Avatar
    FL
    Quote Originally Posted by Johnny O
    Honda Accord 88-89 lxi sei
    Honda Prelude with fi 88-91
    Acura Integra 90-93
    Acura Legend 86-89
    All these cars use the same caliper.
    https://www.3geez.com/forum/showthread.php?t=45900
    I found the same. I think I have the part still I will try and take a picture or 2 of what the differances are.
    http://www1.snapfish.com/slideshow/A...70/t_=85267970
    1999 Penalty Box
    is the teg spindle shorter than the accord spindle? the pics seem to suggest that this is so. if this is the case, it will lower your car some, but it may cause undesirable handling.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    bump. anyone else try this?? pics?? This would be awesome for the guys that will be breaking axles out there
    -Gio
    My E85 Turbo Build
    5280FEST
    89T's Avatar
    Apr 2004
    Looks like you will be doing it,so let me know how it works out. LOL!
    This will help the most with axel breakage.
    http://www.cncbrakes.com/hsb.asp?grp...412&subseries=
    A Mile High.
    lol i guess I will
    -Gio
    My E85 Turbo Build
    5280FEST
  1. Best way to remove a spindle nut
    Last Post: 04-21-2009, 07:50 PM
  2. spindle rebuild thread.
    By lostforawhile in forum 3geez Accords
    Last Post: 08-08-2008, 06:46 PM
  3. spindle knuckle ?'s
    By kji420 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-18-2006, 08:54 AM
  4. HELP, cant remove spindle/axle nut
    Last Post: 09-06-2005, 09:50 AM
  5. Spindle?
    By 88accordlxcarb in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-15-2004, 11:30 AM
