Results 1 to 22 of 22
Thread: benefits of nitriding?
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    what are the benefits of nitriding versus cryo treating? im considering getting my pistons nitrided since theres nobody in the city that does it anymore, so nitriding seems to be an option for now
    race12001's Avatar
    Sanford NC
    Re: benefits of nitriding?
    they both work off the same principals if you research heat treating you can find every thing you need to know about differnt metals and at what temp they do what
    Dec. 05-Dec. 06
    Can you do it to aluminium? I thought it was a flame hardening done to steel. I ll try to look it up I have a book here at work.
    Jun 2005
    Edmonton AB
    Quote Originally Posted by race12001
    so it would be wise to strenghten the otherwise weak pistons going in my block?
    race12001's Avatar
    Sanford NC
    well theyre not week htey have been case harden im sure but if you realy want then hard you will have to normilze them then harden them then aneal them then you would freeze them theres a lot fo money invoved in realy harding them unless tou pushing 30psi of boost or somthing like that you pistons are fine
    Dec. 05-Dec. 06
    Jun 2005
    Edmonton AB
    dont replacement pistons blow up after hitting 15psi or so? when i told everybody the parts i was using to rebuild my motor, they said i shouldnt be pushing more then 7psi since my pistons are NOT OEM, but just a replacement that is OEM specs
    http://metals.about.com/library/bldef-Nitriding.htm
    http://www.matter.org.uk/steelmatter...ess/7_2_4.html
    A one minute google search.
    To who ever :
    Pistons in cars are made of aluminium.
    Stock pistons are almost always cast.
    Custom hi-proformance pistons are almost always forged.
    There is pros and cons of each process.
    http://en.wikipedia.org/wiki/Hypereutectic_piston
    this tells the tale
    Quote Originally Posted by newaccorddriver
    I think if your planning to run 15 psi i would look into pistons that can handle that kinda power level . Anyone of the custom manufactures could tell you what piston they would recommend for that application.
    As far as what "stock" pistons can hold I have no idea. There quite a few "turbo" people on here that have blown up 3-4 engines IM sure they can or could tell you if they were so inclined.
    If you have money it sounds like a good Idea!
    Do it to motor and Tranny!
    1 Million Mile Automatic FTW! jk
    Jun 2005
    Edmonton AB
    mines a 5 speed now, and im curious as to what it would cost, if it costs 25% of what forged would cost, then ill go with forged. if it costs like under $100, then ill consider it an option
    race12001's Avatar
    Sanford NC
    you couldnt do it to an automatic because they have clutches in them with a coating on htem that would burn up during the heat treating process
    Dec. 05-Dec. 06
    LXi User RamThis's Avatar
    N. Richland Hills, Tx
    Nitride treatment is actually a molecular coating that soaks into the metal's outer surface to a predetermined depth. I think it's usually like .005 or .010 or so deep.
    Cryo treatment is the processing of metal at very very low temps. They ramp the temp of parts down to -360F (I think that was the temp I read in the article) over an 8 hour period and hold it there for a certain time to cold soak the part, then slowly ramp the part's temp back to room temp over another 8 hours. This is supposed to change the molecular structure of the metal, relieving all it's inherent stresses and hardening the metal. They have shown machining and cutting tools to last three times longer in industrial applications after being cryo treated. Alot of Taxi and Police cars use brake pads and rotors that have been cryo treated and get 2-3 times the life out of their brakes because of it.
    This is all from memory of course. Some of my numbers may be off but the basic info should give you an idea of the priciples involved..... more research would fill in my gaps and inconsistancies......
    View my Image Gallery
    1989 Honda Accord LX
    2006 Toyota 4Runner SR5
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    Quote Originally Posted by RamThis
    Ramthis = Metal Expert
    LX User skycam_313's Avatar
    Dec 2006
    88 DX Coupe
    hayward, CA
    so which one is better?
    mods:
    stage 4 vacuum removal
    Quote Originally Posted by skycam_313
    Cryo treatment
    Here is the article I had printed out some time back about cryo processing. VERY interesting read....
    http://www.nitrofreeze.com/Heat20Treat20Progress.pdf
    And some other articles they have...
    http://www.nitrofreeze.com/news.html
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    honda nitrides their cranks from the factory, thats why your not supposed to have them turned. On a 15psi boost level, the pistons are def the weakest link, yet, i would say that should be upgraded to a forged piston, cast pistons even with all the coatings and treatments are still gonna break up sooner or later at high boost.
    Jun 2005
    Edmonton AB
    didnt you run 12PSI daily on stock bottom end? im not sure if anybody knows this yet, but this is a trial run of everything. this setup, is meant to use megasquirt(hopefully by this summer), and quite possibly turbo this summer, or next summer. when this bottom end blows(if it does), then thats when the spare block i have from elijah would be put to use at i would be using forged pistons and such in it. i dont need to have an insane amount of power or boost, but i just want that extra little kick in a summer car
    13psi with some spikes at times to 17psi. If you run good managemant with a good tune (CONSERVATIVE) the stock bottom end should be fine. When my motor finally went i had a spun crank main and chewed up main bearings probably due to damage before i boosted the motor anyway, and my pistons and headgasket were fine
    (135000 miles, and you could still see the crosshatch in the cylinders)
    yum.....13psi on stock...that is crazy...i wish i had the money...damn broke 3gee drivers...LOL
    WOW!
    i want that done to my whole car!
    lol
    WOW!
    lol
    lol that would be a 3gee tank....lol
  1. benefits of membership???
    By King Peetis in forum Classic Honda Community Chat
    Last Post: 02-28-2009, 03:38 PM
