Results 1 to 6 of 6
Thread: Spark-plugs
    LX User 89accordex4dr's Avatar
    89honda accord ex 2.0l
    southland,new zealand
    Spark-plugs
    Hi there, the search option not working for some reason but I got a short and sweet question about the spark plug.
    What would happen to my engine if I put too hotter plug or too colder plugs in it? Would my engine detonate and melt a hole in the piston? Just wondered what would happen if I instaled the wrong plugs, cheers
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: Spark-plugs
    If the tip of the spark plug is too hot it can cause pre-ignition leading to detonation/knocking and damage may occur. If it is too cold, electrically conductive deposits may form on the insulator causing a loss of spark energy or the actual shorting-out of the spark current.
    Re: Spark-plugs
    just stick to NGK v plugs.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Re: Spark-plugs
    Messy,
    Even the V-power plugs come in varying heat ranges. The proper plug type (including part number) should be on the tune-up spec sticker under the hood.
    3axap.
    Re: Spark-plugs
    When I changed mine I used:
    NGK Part # 7634 {Standard Plug #BPR5ES11}
    {.044 gap}
    They the OEM Replacement.
    Re: Spark-plugs
    Quote Originally Posted by '89AccordLX(Rus)
    Messy,
    i got mine from rockauto and i got it for a 89 lx-i they seam fine...way better than my old burnt up bolsh that it had. oh yeah a dab of anti seaze helps and they were already gaped to .44 i believe.
  1. Old gas? Spark Plugs? Or....?
    By Soopitup in forum Carburetor Tech
    Last Post: 03-04-2008, 05:25 PM
  2. Help With Spark Plugs
    By dalinxz in forum 3geez Accords
    Last Post: 04-25-2006, 06:52 AM
  3. Spark Plugs
    By FORFREE in forum 3geez Accords
    Last Post: 04-03-2006, 11:14 AM
  4. Spark Plugs
    By skull1441 in forum Performance
    Last Post: 01-27-2004, 04:41 PM
  5. Replies: 4
    Last Post: 11-17-2003, 02:57 AM
