I recently had an 89 dx transmission put into my 87 accord lxi, and it seemed to be driving fine. After about sixty miles, I got an ecu error code, it's a code 12. I looked that up, and it says it's an egr system error. Also after the repair, the power steering isn't working. I will add ps fluid, but that seemed a little strange, I didn't think they needed to do anything with the power steering when replacing the transmission?
Looking up someone else's experience with this error 12, what they did was to replace their egr valve and sensor, but they still got the error. Then other things that were suggested to them were a problem with the vacuum line, or the egu control solenoid valve.
From the kind of work done (transmission put in), does anyone know what is likely the cause of this error?
I turned the car off and back on, the pgm-fi light did not come back on, but the error code is still there in the ecu.
Also, how critical is this error? In other words can I drive this for a while (up to 1000 miles), or does it need to be corrected right away?
